Gel Coat Correction?
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by 3PedalMINI, Apr 8, 2013.
  1. 3PedalMINI
    3PedalMINI DB Forum Supporter
    I have a jetski and want to get it ready for the season, Part of that is wanting to take care of the minor swirls. What would you guys recommend i use to correct it? i have Menzerna polishes but dont know if i should just make it easier on myself and go for the 3M gel coat polishes?
    Thanks! :thumb:
  2. junebug
    junebug Jedi Nuba
    Depends, I've done a few boats and the gel coats were old and oxidized really bad. In those cases, Shurbuff's Buff Magic, wool pads, an a rotary will save you a ton of time and back pain. If its just light swirls, your Menzerna polishes should work,
  3. Perfections
    Your menzerna is fine.. Anything sip and above in cut and you're good.
