gear lube for the makita?
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by GDAL, Nov 15, 2009.
  1. GDAL
    GDAL Guest
    Guys,
    I got my makita today. I'm really excited about the whole thing and I can't wait to start some polishing.
    I gotta a question though ... what kind of gear lube do you guys use to lube the gears? I read somewhere in this forum that some people here use Amsoil and it really quiets the machine down.
    I have had great sucess with Amsoil products specially when I used to ride motorcycles. Clutch engagement was so smooth after an amsoil oil change.
    Any advice guys?
  2. kustomizingkid
    kustomizingkid Nuba Guru
    I don't know why you would tear it apart and lube it... my two grinders that live in much much much worse environments are old as hell and work great still...
  3. GDAL
    GDAL Guest
    I thought it was part of the preventative maintenance you have to give these buffers along with the carbon thingies on the side.
  4. RustyBumper
    RustyBumper Jedi Nuba
  5. GDAL
    GDAL Guest
  6. RustyBumper
    Just checked my inbox. Did you send me something today? :shead:
  7. GDAL
    GDAL Guest
    just sent it like 5 mins ago.
  8. Chas
    Chas DB Forum Supporter
    Yeah that was a thread I started awhile back, what I thought was potentially was a major problem ended up only being some lube that was coming out of the head near the spindle. I took it apart and just cleaned it up a bit and haven't had a problem since. I don't think there is much need to replace it or anything. The lube should last you a long time.
  9. RustyBumper
    PM'ed you back.
