G.K: Tuscan Tvr
Discussion in 'Professional Detailer's Studio' started by Jayplay, Feb 13, 2008.
  1. Jayplay
    Jayplay DB Pro Supporter
    This car is driven all over Europe once a year and cleary showed as it is ridden with stone chips and was in dire need of some tlc. Owner is having the front end resprayed in coming months so stone chips were left untreated. vehicle was badly swirled and lots of holgrams were visible.
    Firstly wheels were cleaned with As smart wheels and a assortment of brushes. Inner's were covered in tar and theis was removed with AS tardis
    Car was then foamed and washed with SV Autobathe then clayed with SV Paint rubber and last touch as lube. Dryed with Sonus drying Towels
    Paint was measured with the positest 200 and showed very low readings with most panels averaging 60-70 microns. Some of the rear panels had been resprayed
    Defects:
    Most polishing was done with Menz 106fa and few panels were hit with Menz 3.02. Due to the low paint levels some remaining defects were left. This was then followed up with Megs #80 and then SV cleaner fluid by hand and finally a coat of Divine.
    Afters
    Wheels were cleaned with SV cleaner fluid and then coat of SV Autobahn
    Tyres and wheel arches treated with SV Pneu
    Exhausts cleaned with SV metal Polish and carbon polished with and then a coat of wax
    Due to the lower paint readings only about 85% correction was achieved but still a great improvement.
    thanks for looking
  2. FMINUS
    FMINUS DB Pro Supporter
    Wow what a great detail!!!!!
    What composite is the body on this car made of?
    How many tubs of Divine have you gone through?
  3. Jayplay
    its made of fiber glass Fminus
    Half way through first pot.. As its a very hard wax you tend not to use much. I apply by pad instead of hand aswell which results in using less
  4. pirex
    pirex DB Certified Dealer
    Very nice work! The car is looking stunning!
  5. klumzypinoy
    klumzypinoy Nuba Guru
    Mmmmm Tvr :druling: That's a sweet detail!
  6. ggk
    ggk Jedi Nuba
    man i want one! but to get one ill have to move to GB cause they dont pass bumper specs :(
    if only i could have one, lol
    very nice detail, but did you get all of the tar on the inside of the wheel?
  7. Nica
    Ooh what a vehicle and talk about curves...man if that thing had any more curves I would have a hard time choosing between my wife and that vehicle hahahahaha
    Seriously though, that vehilce has some incredable curves. The correction turned out quite nice, just curious what pat did you use? The readings were quite low too, see aren't you glad you have the PosiTector 200 :thumb: it comes in handy.
    Oh man your lucky, you get to use Tardis. I tried getting some but the shipping is really tight, it has to be a certified shipping company to pack it and it can only travel via air to get to Canada. Rich is still working on getting me some Tardis but till then I can only dream of using Tardis :acry2:
    Vehicle looks great Jayplay, thank you for sharing :applause:
  8. detailersdomain
    jayplay nice write up with great results!
  9. Divine Detail
    Top notch work, Jayplay. I'm extremely impressed with the car; Carlos is right, talk about curves.
  10. Pats300zx
    Stunning...beautiful job...
  11. Jayplay
    pad used was a 3m ultrafina pad (blue)
  12. Jayplay
    thanks for the comments guys
  13. sneek
    sneek Nuba Guru
    wild....just wild..
  14. Nica
    Nice :applause2:
