FS: Set of 2 Rupes (6 inch) Yellow Polishing Foam Pad +Meguiars Xtra Cut
Discussion in 'Sale, Trades, or Bargains' started by NikolaTesla, Aug 14, 2016.
  1. NikolaTesla
    NikolaTesla New Member
    Set of 2 Rupes 150mm(6inch) Pads - Brand New:
    This pad is the third step in the Rupes Big Foot Polishing System. The Yellow Polishing Foam Pad was designed to be used with Rupes Keramik Gloss Fine Gel Polish to remove light swirl marks, holograms, clay-induced marring, and other light paint imperfections. This pad finishes exceptionally well considering the mechanical polishing ability that it provides. Please note: There are two very small marks on the yellow pads, this was from the factory.
    1 Set(2 Meguiars DA Microfiber Xtra Cut Discs) - Brand New:
    Meguiars DA Microfiber Xtra Cut Discs are designed to remove deep swirls and scratches with your DA polisher. Each specially engineered microfiber strand acts as an abrasive that makes heavy-duty paint correction possible with your DA polisher. Meguiars DA Microfiber Xtra Cut Discs remove paint imperfections without creating swirls! Meguiars guarantees it.
    Please see eBay link:
    http://www.ebay.com/itm/262571402693?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
    ​If you would like to bypass eBay and make and offer, just let me know.
  2. NikolaTesla
    TTT
    Thanks!
