FS: Foam Cannon
Discussion in 'Sale, Trades, or Bargains' started by Cooter, Jan 2, 2011.
  1. Cooter
    My Karcher took a crap on me. My wife bought me a Stanley (who knew they made pw's) for Christmas. So now I'm selling my Foam Cannon.
    FS Foam Cannon for electric Karcher is SOLD
  2. kdude
    kdude Jedi Nuba
    Just curious how long to the Karcher last ? I bought one at Costco about three months. Maybe i should return mine?
  3. Cooter
    I actually bought a refurbished one at Big Lots. Lasted around a year. It was actually a failure with where hose screws into the the front of the machine. The plastic piece of the hose that screws into the karcher itself broke. It was screwed into the machine. I moved the machine and the hose fell off. I picked it up to inspect it and noticed the hose and broke. So, actually not machine failure.
  4. KlineS157
    KlineS157 Birth of a Detailer
    Can i change the connection on this one? If so i'll take it
  5. Cooter
    I'm not sure. I would contact advs1 to make sure. He's a member here. Sorry, I cant answer your question.
  6. advs1
    advs1 DB Forum Supporter
    Yes you can change the fitting. Depending on your model pressure washer and/or trigger gun you have.
  7. Cooter
    Man, you came around at the right time!!! Thanks!!!!!!
  8. advs1
    LOL it's called insomnia! LOL if any potential buyers need info on adapters feel free to pm me.
  9. 911Fanatic
    Just take the Karcher adapter off and use 1/4 quick connects. You may have to replace your handle on the new pw but they are cheap. Let me know if you need a hand.
  10. Trents_goat5.7
    Trents_goat5.7 Jedi Nuba
    So this will work with any Karcher pressure washer?
  11. 911Fanatic
    There is a retail or consumer ( K ) line I believe and a commercial line. I'm pretty sure the one here is from the consumer line.
  12. Cooter
    I believe it will work with any electric Karcher.
  13. agpatel
    agpatel OD On Detailing
    Correct this will work for any consumer Karcher...if you have a commercial one you will have a threaded end and not a twist.
  14. AutoObsessed
    AutoObsessed Dealers
    Yes the one you have is the consumer line adapter just like 911fanatic and agpatel mentioned.
    7 fittings are available that fit most pressure washers, they run for $10 us or $15 cdn each.
