FS: cyclo polisher and chraftsman 2spd rotary
Discussion in 'Sale, Trades, or Bargains' started by Misha, Jul 1, 2010.
  1. Misha
    Misha Nuba Guru
    ok we cleanning shop a little and need to sell some stuff that we dont use.
    Cyclo was used 2-3 times and was purchased in jan of 2009. works fine, just dont use it anymore
    asking price is $250 OBO
    chraftsman rotary
    2 speed, not sure what thread it is, doesnt look like 5/8
    nice thing is that handle rotates 180 degrees
    asking $80
    here is info that i was able to find on it
    Craftsman 2 Speed sander/polisher with 4.5 amp motor is great for most sanding or polishing tasks. The trigger switch controls the two speeds and can be locked-on for extended use. The tool's rear handle rotates 90 degrees and the side handle can be mounted on top, right, or left side. A spindle lock makes it easy to remove or install the rubber pad.
    * 4.5 amp motor - provides power for most all sanding and polishing needs.
    * Two Speeds (1400 & 1650 RPM) - Lower speed for polishing; Higher speed for sanding
    * Rear Twist Handle - rotates 90 deg with push of button for more comfort and control
    * Spindle Lock w/pin provided - for ease of changing paper, pads, or bonnets
    * The extended length, two finger switch w/lock-on - provides more control and comfort during extended use
    * Auxiliary Handle - mounts left, right, or top for added control
    * Ball and Sleeve Bearing - permanently lubricated for long service free life
    * Live Tool Indicator - glows green to make user aware of current to tool
  2. buick66s
    buick66s Virgin Detailer
    Would you take 175.00 for the cyclo polisher
  3. Misha
    Misha Nuba Guru
    175 shipped or plus shipping?
