Video of Test spot on driver fender : Ford GTCS done by ProReflection , Test spot - YouTube Test spot on driver fender: right side corrected , left side swirlcity: Before: After: Before: After: Before: After: Hood corrected: After completed , few sun shots: Process: onr wash , and claybar with onr as lube , tape the trims the correction was made by sip on lc green light cutting pad and flex da , polish done with 205 on hex polish pad and da, 2 coats of opti-seal on wheels i use wax and m40 on tires.
Porsche Porsche done by www.proreflection.com - YouTube Before , swirlcity Scratch before: Scratch after: Before: After: ALL pictures are after: Process: onr wash , and claybar with onr as lube , tape the trims the correction was made by sip on lc orange cutting pad and flex da , polish done with 205 on hex polish pad and da,duragloss 105 on wheels i use wax and m40 on tires
visual , as darken the tire is around 2 weeks , i have seen up to a month. i did not test it with water to see if is still there
