Foam w/o Stripping Wax?
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by slanguage, Dec 6, 2009.
  1. slanguage
    What dilution ratio would I use to foam my truck down without stripping off the wax?
    I have athe pwMall FC and want to foam down my truck, but leave the wax unharmed.
    I have the following soaps:
    CarLack 68 Shampoo
    ONR
    Meg's #00
    Meg's Hyperwash
    DG 901
    1Z Perlz
    CG CWG
    CG CWC
    Tropi-Care Citrus Wash
    Autoglym Bodywork Shampoo
    Pinnacle Bodywork Shampoo
    Majestic Solutions Super Foam
    Thanks In Advance,
    -Roger
  2. supercharged
    Try Megs Hyper Wash (least aggressive), or DG #901/902 (a bit stronger) - 2-3 oz in 32 oz bottle, fill the rest with water...
    If you use CWC or CWG at good foaming ratios, they might strip your carnauba LSP...
    Best foaming shampoo I've used up to date is DP Xtreme foam formula, it is real snow foam!
  3. slanguage
    ok. cool. my lsp is AJT topped with 845.
  4. togwt
    LSP stripping is a function of the type of concentrate used, more so than the dilution ratio. DP Xtreme foam formula 1-2 oz is a great snow foam
  5. supercharged
    Try the least aggressive approach first 2-3 oz of Hyper Wash...If needed, add an ounce of CWC or CWG to that mix...
  6. slanguage
    the hyperwash worked fine. just got done washing and dry with a coat of aquawax :D
  7. blackjz
    blackjz Jedi Nuba
    i usually foam with OPT car wash without stripping LSP..
  8. agpatel
    agpatel OD On Detailing
    That is what I use ans it foams pretty nice in a foam gun and bet even better in a foam lance.
    Out of the soaps you have I would do what supercharged said and try hyperfoam.
  9. billy
    billy Obsessive Detailer
    +1:thumb:
  10. Tech
    Tech Any Rag Vehicle Washer
    Are people foaming when doing weekly washes?
    I'm looking to do so just because I love to use the foam lance. I dont want to deteriorate my LSP at every weekly wash though. Right now, I ONR wash weekly.
  11. slanguage
    Foaming weekly wont hurt the LSp if done in the right dilution ratio/ right soap used.
    It would be the same thing as washing weekly, and not stripping your wax by using the same procedures and soap.
  12. Tech
    Some ratios/concentrates have to be better than others for regular washing.
    I like Perls for traditional washing, but it's not very "foamy" via the lance.
    ONR is nice when added to Citrus Wash and Clear also. But again, Im concerned with stripping.
  13. slanguage
    Meguiar's Hyperwash is nice thru a foam lance. creates pretty good suds, and 1-2 oz per 32oz bottle (rest filled with water) does a nice job in creating a pretty good amount of foam. and at that dilution ratio will not strip wax.
  14. MikeyC
    MikeyC Two Bucket System Washer
    I alternate between Optimum and Poorboy's SS&S in my foam cannon. Both work really well and won't strip the LSP. I just throw a couple ounces in a 32 oz. bottle and fill the rest with warm water. Using warm/hot water I find helps the soap to dissolve in the bottle since 2 oz of soap in 30 oz of water is a high ratio as the soap is designed to be used 2 oz in 3-4 gallons of water.
  15. Esienmann_M6
    Esienmann_M6 Two Bucket System Washer
    it also depends largely on what type of soap you using for the foam canon or foam gun for that matter.
    for example you can use as much soap from Dodo juice wash and wax soap which is green
    in color, it mainly uses nuba for extra shine and protection, but on the other hand you can only
    use 1-3 ounces of 3M soap or any other soap that does not have nubas in it or gloss enhancers.
  16. Dust2Glory
    Dust2Glory Nuba Guru
    dude you need to mix opt car soap and dg 901 50/50 and see what happens?!?!
  17. Tech
    result is??
