I just did my first application of OPT Optiseal and used the foam applicator that came with it. Don't use foam pads for anything (I guess other than the foam buffing pads for my PC). So how do I care for the darn thing? How do I wash it out? TIA, Tony
I have always cleaned foam pads with an APC, spray it on, scrub the pad, rinse, spray again and scrub let it sit for a min and wash it out then keep doing that till it is clean. You can use a brush for polishes that don't like to come out. You could also get some snappy pad cleaner or DP pad cleaner powder and let them soak for 30 min or so (Can do this with APC as well) and then rinse them clean.
