1. bmw335icoupe
    bmw335icoupe DB Forum Supporter
  2. xabo
    xabo Virgin Detailer
  3. bmw335icoupe
    Ok thanks. Here is the fitting from the pressure washer. Which one of these will fit. I thought Bosch but the problem is that there are 2 O rings on mine.
  4. bmw335icoupe
  5. InsanePaint
    InsanePaint Pro Detailer
  6. Darklol
    Darklol Any Rag Vehicle Washer
    I'm not sure it will work. Those look like the Simoniz ones from Canadian Tire. I had the same issue I couldn't fit the foam lance on it.
    First one I bought having the issue:
    And then I went back exchange it with this one: Coleman 1900 PSI Electric Pressure Washer | Canadian Tire
    Direct fit and it already has a quick connect.
  7. Darklol
  8. bmw335icoupe
    Thanks so much guys!!!!
  9. xabo
    The fitting that came with the lance fits perfectly on mine.
  10. xabo
    Sorry man......I just noticed that you have the 1400psi and mine's the 1700-1800 psi..........different fittings.
  11. top189h
    top189h Virgin Detailer
    If you find a way to get one to work, please tell me how. I have the same pressure washer and have tried three times to make something work, and I have yet to find one.
  12. bmw335icoupe
    Figured it out. You have to replace the standard hose with one that will fit a new wand. I bought a Briggs and Stratton from sears then bought a hose from Home Depot that fits an m22 style nozzle.
  13. top189h
    Awesome, thank you
  14. bmw335icoupe
    Your welcome!!!!
  15. bmw335icoupe
    Also the sprayer I bought didn't come with a new nozzle and if you use it without a nozzle it doesn't work as well so either buy a new nozzle or just use the foam lance. Or just switch out hoses.
