foam gun/ canon how do you foam
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by armenakadino, Apr 29, 2011.
  1. armenakadino
    armenakadino Birth of a Detailer
    I was wondering whats everyones method with the foam gun do you
    1. foam the body leave the suds on and just go with the 2 bucket method
    2. foam the paint let it dwindle to bring the dirt down rinse and foam again and then go with 2 buckets
    3. foam the paint, rinse then do the 2 bucket method.
  2. supercharged
    Foam, let it dwell, rinse off, then wash...
  3. Bmer89
    Bmer89 DB Forum Supporter
    I usually use option 2, if I'm using the same soap in the foam gun and bucket. Otherwise, depending on how dirty the car is, I'll foam and rinse once or twice, then 2BM.
    Sometimes I foam bystanders as well. :)
  4. Danny
    Danny Nuba Guru
    This:)
  5. dankfanatic
    dankfanatic DB Forum Supporter
    i alternate between method 1 and 3, depending on how dirty my car is.
  6. irontree
    irontree Two Bucket System Washer
    This is what i do too. I use onr for the final wash in the garage.
  7. Bunky
    Bunky DB Forum Supporter
    I use option 1 one time and for some reason I did not like it. It seems like too much so option 3 when I use a foam gun. It is half entertainment value for about 50 cents.
  8. M3ride.
    M3ride. Wax on..Wax off
    I always use method #2. Works the best I think.
  9. kyoshiro
    kyoshiro DB Forum Supporter
    i foam, dwell, straight to 2BM then rinse then wash again
  10. armenakadino
    I'd expect more to do option 2 but thinking of its pretty wasteful that's what I always been doing
  11. Misha
    Misha Nuba Guru
    #2.
    foam. let it run down. wash with powerwasher to get most of dirty off so only thats gona be on it is gona be dust pretty much so less change to scratch the paint. then 2bucket method. thats what i do
  12. Kilo6_one
    I put on some Paul Oakenfold, bust out some glow sticks and.............. oh wait, for cleaning a car, I thought you were talking about something else LOL
    I foam, let it dwell wash it off, then 2BM.
  13. Deep Gloss Auto Salon
    Power clean
    Foam
    Let dwell
    Power wash
    Foam
    Let dwell
    Bucket wash
    Sent using Tapatalk
  14. rwisejr
    rwisejr DB Forum Supporter
    I use option 3 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  15. BoostedMk6
    BoostedMk6 Jedi Nuba
    Rinse - Foam - Dwell - 2BM Wash - Rinse
    I find that by washing a few minutes after foaming gives me better lubricity.
  16. Chaseme
    Chaseme DB Forum Supporter
    Trigger handle pressure rinse - Foam - Dwell - Rinse - *Foam again for extra lubrication - 2BM Wash - Flooding rinse
    *not every wash
  17. BoostedMk6
    Stupid question - with a foam cannon, do you guys turn the water supply going into the power washer on full blast?
  18. Chaseme
    Just because it is a "powered washer" doesn't necessarily mean it needs a full water supply....at least, that's what I would imagine.
  19. BoostedMk6
    Reason i'm asking is because i'm not getting thick foam no matter which soap and dilution ratio I use.
  20. Danny
    Danny Nuba Guru
    I am betting its your water are you using water from the tap or distilled or filtered water. If your water is hard its not going to foam up well. I use soft water that is filtered from inside my home since we had it installed a water softening unit a few years back and I get shaving creme foam with 2oz of CG Maxisuds II to 1000ML of water. I live in the desert and we have very hard water, when I used water from the tap outside the first time foaming was not that great at all now I always use the soft filtered water we drink from inside and and premix the soap and water by shaking up the bottle to get an even consistency while foaming since Maxisuds II is some thick stuff.
