Foam Cannon???
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by sal329, May 3, 2009.
  1. sal329
    sal329 Nuba Guru
    I will be picking up a Karcher gas powered pressure washer tomorrow. I am looking to attach a foam cannon to it. I have done searching and found that with the Karcher you need some special attachments? Is this for both gas and electric? Or only the electric? Anyone know a good source to get all I will need to use a foam cannon?
    Thanks
  2. richy
    I can only advise on the electric version but if the ends are the same (I would assume they are) then you need 2 additional pieces:
    this and
    this
    I bought the cam spray model and love it. Happy foaming!!
  3. sal329
    sal329 Nuba Guru
    After I pick it up I will snap some pics of the handle to double check. Thanks for the help
  4. ptirmal
    ptirmal Virgin Detailer
    The attachments are meant for electric washers, the camspray comes with standard (I believe 22mm) connections to screw into your pressure gun which should be a standard gun since it's gas. It might also include a quick connect attachment, my camspray did.
