Foam cannon
Discussion in 'Car Detailing Product Discussion' started by EvoFire, Jun 20, 2010.
  1. EvoFire
    EvoFire Birth of a Detailer
    I think that's what its called?
    I see you guys posting pics where the car is covered in foam. I was wondering how that works, and what equipment I would need to get. I don't want to step into too much at once, so I want some info regarding this. If it seems like easy enough to do, I'll take the plunge.
    Thanks guys.
  2. durabio
    durabio Birth of a Detailer
    It is called a foam cannon or foam lance on the other side of the world I think. Basically you put wash soap into the container and make a solution. Depending on how you diluted your solution determines the amount of foam, atleast for mine. The cannon attaches to your pressure washer, sometimes you need an adapter, like for me I need a quick connect piece that will connect from my pressure washer gun to the cannon. I found a cannon on ebay and bought a pressure washer at home depot.
