Foam Cannon bottle quick disconnect?
Discussion in 'Car Detailing Product Discussion' started by n023b, Jul 20, 2012.
  1. n023b
    n023b Virgin Detailer
    Hey guys I have the autogeek foam cannon and I love it besides having to always screw and unscrew the bottle to rinse the car off I was wondering if there was some type of quick disconnect I could use to quickly connect and disconnect the foam cannon from the power wash gun?
    Thanks
  2. Chaseme
    Chaseme DB Forum Supporter
  3. n023b
    I actually have a set of those very ones. How would I attach these to my foam cannon and pressure wand?
  4. n023b
    Bumppp
  5. rwisejr
    rwisejr DB Forum Supporter
    What is your current setup ? Picture of wand and canon connected.
  6. n023b
    I have a simioniz pressure washer but the pressure wand is very similar to this it uses the same kraznie fitting
    http://www.autogeek.net/foam-cannon-how-to.html
  7. Rcrew
    Rcrew Wax on..Wax off
    Head down to the local hardware or home improvement store and visit their lawn/garden section. They should have all kinds of brass adapters, reducers, quick connects etc. You can even take your cannon in and play around with stuff.
  8. rwisejr
  9. n023b
    Thank you both I will head down to HD tomorrow and buy both it will make life a lot easier.
    So I'm guessing one of my pressure washer nozzles will connect directly to the quick connect do you guys think there will be a problem since there will be no wand just the nozzle on front of the gun? I hope that makes sense.
  10. rwisejr
    You should be fine that way. If for some reason you want the length of the wand. Just buy another of the second adapter .
