FMINUS Detailed: 2007 Lexus GS450h Black CG CWC CG Grime Reaper CG fabric protectant CG BareBones CG New Car Solvent SprayAway Glass Cleaner 1Z Cockpit Premium 1Z Blitz 1Z Glass Polish P21S TAW P21S Gel Wheel Cleaner CD2 Leather Master Trio OPT QID OPT Interior Protectant DG Aquawax Clay: CG Green CG SQD as Lube Paint Correction: Menzerna 106FF CG MPT WHITE Pad Zymol Duster Equipment: Defelsko P6000 Defelsko P200 Defelsko Wireless Printer Defelsko Posisoft Dell Laptop MyteeLite II Therma Steem Brinkman 3m Sun Gun 3m backing plate CM5300 Metabo Protection: CG Jetseal109 LSP: Wet Obsession
Damn fine work Phil! Making that black look GORGEOUS again. You certainly get your share of beat up paintjobs... Tell the owners to use proper washing and drying techniques!!! PS: throw away that old Sony camera and start using your 400D!!!
dude ur like an asian Paul Dolton... you need to come out with your own wax and tV show!!! pehnominal job.... black yet again flawless
Great work as always. I think you may have overtaken Toto as the master of Black cars! Some very fine work there. And Piet if folks didn't treat their paint like they do then FMINUS wouldn't have anything to do!
Amazing work on that black car like always Phil, it finished down very nicely. Again great work Bud!!!!:applause2:
It's the missing h!! Great work Phil, those reflection shots are wicked. A question about the CG Fabric Protectant, what do you usually spray it over and is there anything else you need to do after spraying it? Thanks!
NO way! I need something I can throw around. TWSS What does yours look like? :headbang: Toto will always be the master! :headbang: :headbang: CWC 3 oz I just spray agitate w brush Its a great wax, especially for the price.
Phil...that is one fine correction job...I really mean it...you do great work.. That Wet Obsession looks real nice on that Black paint...you can compete with some of the best now..real nice work Al
Thats right and just remember FMINUS is using a foam cannon and not a foam gun. Those are two entirely different beasts. If you are using the foam gun like you get at AG and from Gilmour then you will never get that type of foam regardless of the soap you use. To get that type of foam you need a foam cannon and pressure washer. If you are using a foam cannon then you can use 2-3 oz of CWG and set the setting on max.
