When i stop and then start, the motor kicks in very abruptly, not sure if my switch is bad, or if something else is the culprit. Anyone else have this problem?
you can call up flex and check they are extremely good with this stuff. are you sure that your not bumping into the switch at all.
Thanks Phil, was thinking of giving you a call. No, i have a feeling it's in the switch. If i go off and on with the switch, it will bump up speed real abruptly, and i mean bump up speed. Here of late the switch hangs up, and if i release it on its on, it will go into its normal position, as before sometimes it would keep spinning by itself after releasing the switch as you normally would release it. If i have time i'll get a hold of Flex. This kinda is a bad time, someone has asked me to do 2 black Mercedes this weekend.
