FK Paint Decontamination Kit..Who's Used it??
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by Deep Gloss Auto Salon, Nov 6, 2007.
  1. Deep Gloss Auto Salon
    Has anyone used the FK Paint Decontamination Kit? I have been looking at it for some time but have not heard much about it from detailers I trust so I figured I'd ask the DB crew.
    Below is the product link.
    http://www.fk1usa.com/decontamination.htm
  2. klumzypinoy
    klumzypinoy Nuba Guru
    sounds like an interesting product..
  3. Deep Gloss Auto Salon
    *Bump*
    I really want to get this for my upcoming season... any/all feedback on this product or a superior product would be greatly appreciated!
  4. togwt
    Acid Decontamination and Neutralization:
    Acids, which includes industrial fallout (IFO), rail dust, acid rain, hard water spots, road tar, bird excrement, acid residue, oxidation, adhesive residue, road grime and rust stains introduced via ferrous metal deposits and other forms of pollutants. If the affected paintwork is not neutralized any remaining acid residue will be reactivated each time it comes into contact with water.
    Water contains 2- hydrogen and 1-oxygen atom. Oxygen is an oxidizer; ozone is an allotropic form of oxygen (an oxidizer is any component that emits oxygen); many chemical compounds react to slight heating and an oxidizing process. So now you have an acid + water +oxygen + ozone all of which equates to a highly concentrated acidic solution, which causes a concave indentation (acid etching) on the paint surface, which will eventually compromise the paint system through to the clear coat.
    This 3-part system from Automotive International - A B C Decontamination / Neutralization system
    (http:// Automotive International - Valugard Product Line) comprises; A-Acid Neutralizer, B-Alkaline Neutralizer (Use detailer’s clay and the alkaline wash to remove stubborn ‘water spots’) and C- a pH 7.0 Surface Conditioner, which safely removes both surface and subsurface contamination and neutralizes any residual acid from the painted finish. Any subsequent etching requires an abrasive to level the paint surface
    System comprises:
    •A is an acid neutralizer that removes waxes, storage stains and neutralizes acid deposits, a solution of an 8:1 concentrate /clean water , allow to dwell for 5-7 minutes before rinsing.
    •B is an alkaline neutralizer, removes alkaline deposits and ferrous metal fallout, allow product to dwell for 5-7 minutes, works well with detailers clay to remove contaminants.
    •C is a pH 7.0 surface conditioner a 128:1 concentrate vehicle wash and the third step in the neutralization process, which ensures any chemical residues, are neutralized and rinsed away.
    Use separate wash mitt for products A and C, the use of the ValuGard Dispenser trigger spray container for products will ensure correct mix ratio and maximum economy
    Information resource-Automotive International- Automotive International - Valugard Product Line
    Product specific- http://www.autoint.com/tsb/tsb04-09-06.pdf
  5. Deep Gloss Auto Salon
    Thanks togwt: I've actually done some research on this and am missing one last peice - first hand opinions from people who have used it.
    have you used it?
    Your thoughts of the product?
    I have been tinkering with the idea of performing annual decontaminations and was wondering if this is overkill?
    thanks in advance!
  6. jshillin
    jshillin Birth of a Detailer
  7. Grouse
    Grouse DB Forum Supporter
    FWIW FK1's seems to be a clone of Auto Internationals 3 step.
  8. Deep Gloss Auto Salon
    Interesting, wonder if fk sells it to them.. what's the price difference?
  9. Grouse
    No, auto Int is the originator of the product. FK tried to copy the process.
    Ron ketcham was their sales manager from 87-95.
    Once he left, they started to try and follow what he was doing there, except never made the committment to clean all the toxics and such from the product formula's.
    FK1's product is not valugaurds abc wash system. It is a process that appears to be the same but is not as safe overall.
  10. FMINUS
    FMINUS DB Pro Supporter
    I have also heard that Valugards product was better
  11. togwt
    Living at the beach I do a decon wash bi-annualy.Auto International is my preference
  12. Deep Gloss Auto Salon
    Hmm so living in an area witn salt on the roads as I do sounds like I can justify a post winter decon regimen...
    Thanks fella's looks like I'll be getting this.. Edit: I just dod a google search using "Auto International paint decontamination kit" and came up empty handed... would you happen to have a link you wouldn't mind sharing?
    Thanks in advance!
  13. FMINUS
  14. FMINUS
  15. sneek
    sneek Nuba Guru
    X2 from a few good people
  16. richy
    Looks very interesting..I see they have a paint gauge on there as well. i gotta a call into their product guy Tim..I am gonna ask him a few qu's about their products.
  17. FMINUS
    Can you find out whats the difference between the 3 step and their ONE STEP AUTO PREP?
  18. Deep Gloss Auto Salon
    that would be awesome!! +1
  19. FMINUS
    Waiting on your response to place an order!
  20. FMINUS
    Any updates?
