Finish Kar e Ultimate Wheel Cleaner / Degreaser
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by Reflect, Jan 20, 2009.
  1. Reflect
    Has anyone used Ultimate Wheel Cleaner / Degreaser? It's 25 bucks for a gallon, and it says it is coated and uncoated wheel safe. Does this mean it's safe for all wheels? I'd really like to have a stock of wheel cleaner without running out all of the time.
  2. Reflect
    Bump.
  3. pektel
    pektel DB Forum Supporter
    I use Optimum Power Clean. But it was more in the range of 35/gallon. It works very nicely at 3:1 on both wheels and tires. Especially wit the foaming spray head that Justin includes.
    I like the product since I can use it on interiors as well. Lots of different uses, only one bottle.
  4. bigpoppa
    bigpoppa Jedi Nuba
    Last time I checked they were out of stock.
  5. Reflect
    Have you tried it? I wanna know if it's worth buying.
  6. Reflect
    Out of stock right now.
  7. 2KLS1
    2KLS1 Birth of a Detailer
    I've been using it for a few months. Its probably not the strongest wheel cleaner but I can't say for sure, I haven't used many different cleaners and my wheels never really get that dirty. I like it though. I have aluminum wheels with patches where the clear has come off and this works great. It doesn't dull or tarnish the finish at all. I like using it with a foam sprayer and a foam brush. I would recommend it.
  8. Reflect
    Are you using it diluted?
  9. 2KLS1
    Yes, its a concentrate. Right now I'm using it at 4:1.
  10. Reflect
    Do you think you could dilute it so it's a little stronger? Maybe that's your problem. (Doesn't seem like a problem, just if you needed a stronger solution)
