for some reason the sprayer on the bottle kinds sucks. I know it is a foaming head but the stream it puts out is very narrow and it takes a lot of product just to evenly cover everything. I just used half of a 500ml bottle on one set of wheels(face, barrels and tires). How much are you guys using? Are you just using it as a wheel cleaner, or tire cleaner, or wheel and tire cleaner? Anybody using a normal sprayer head? [BTW this is an awesome wheel cleaner. It gives the wheels a nice shine and is one of the best damn tire cleaners I've used. I couldn't imagine the crud it was pulling out.]
I actually have some that I haven't tried yet as I was worried it wouldn't clean well enough (for a test) on a clients car(s) but now that you mention it's good, I think I'll try it out this weekend. If you don't like the way it sprays, try swapping out the nozzle with the one from their Tyre Shine. I believe it sprays wider.
You can cut it 1:1 with water as indicated on the back of the bottle. I only use it 1:1 and with a Kwazar Mercury Pro sprayer/bottle.
I agree. The sprayer foams well but sprays at too sharp of a stream. I swap into another spray bottle.
Thanks guys, I guess I'll just swap it out for a regular sprayer. Sucks cause I like the foam cause it clings better.
I use $4 "pro" bottles from Canadian Tire... great spray pattern (adjustable to your preference) and it holds a lot more which means less refilling for me.
