Ferrari Testarossa: wetsanding + supernatural
Discussion in 'Show and Shine' started by Todd, Jul 23, 2008.
  1. Todd
    Todd Banned
    I had detailed this particular Ferrari about 8 months ago. Since then it was involved in an accident that required some touch up work. Unfortunately while they redid the rear quater panel they also took a hand at filling in some paint chips and sanding them level.
    I was unsure what they used to sand the touch up dots, but it looked like razor scratches on the clear coat.
    Process Outline (quick)
    Wash with Dodo Juice "Born to be Mild" car soap, two buckets
    Clay with Meguiars' "Red" clay using Last Touch 1:1 for lubricant
    Blow dry and blot with a waffle weave.
    P21s Wheel Gel on rims, aggitated with a Swissvax wheel brush
    P21s Wheel Gel on inner rims, aggitated with an EZDetail brush
    Meguiars APC 7:1 on wheel compartments and tires
    Paint Correction:
    Fix paint sanding scratches with Meguiars Unigrit 2000/2500/3000, wet
    Compound entire Ferrari with Meguiars M105 on a Meguiars So1o Wool Pad at 1800 RPMS via Makita Rotary x 2-3
    Polish entire Ferrari with Meguiars M83 DAC/P on a Meguiars Diamond
    Cut So1o Pad at 1500 -> 1200 RPM x 1
    Polish entire Ferrari with Meguiars M80 "Speed Glaze" on a Meguiars 8006 Polishing Pad on a G100.
    LSP/Dressing/ECT
    Dodo Juice "Lime Prime Lite" via hand, soft german foam pad
    Dodo Juice "SuperNatural" x 2 coats by hand using Meguiars Gold Class applicatior
    Meguiars Hyperdressing 3:1 on wheel arches
    Meguiars Hotshine Tire dressing x 2
    Jeff Werkstatt Prime on rims
    Meguiars NXT Metal Polysh on exhaust tips and wheel knock off hubs
    Meguiars NXT Window Cleaner on windows
    Okay some pictures...
    The first picture shows one of the several spots of concern in the paint. The deep "swirl" marks are actually sanding marks that ran very deep into the paint. Trying to compound these out would remove a large amout of paint so I choose the slow and steady process of wetsanding. Inital paint thickness was in the 5.3-5.5 mil range over the panel.
    Here is the same area after sanding with 2000/2500/3000 grit and polishing out with several steps... There is still a slight haze in the paint from the "DAC/P" and the meduim soft paint. After the aggressive correction the paint was showing 5.2-5.3 mils.
    The center of the trunk also had these deep scratches around the emblem. When I took this picture I had already been sanding with 2000 grit (up and down) but you can see the deeper scratches running in great frequency across the width of the panel.
    Flattened down more and finished sanding with 3000 grit. It was no perfect as I had already taken 2/10's of a mil off and did not want to penetrate the surrounding original paint any further.
    After polishing out.
    Working M80 "Speed Glaze" into the paint until it "clears"
    Sparringly applying the "Lime Prime Lite" glaze and precleaner
    Two thin coats of Dodo Juice SuperNatural applied and left to cure.
  2. Todd
    Todd Banned
    After Pictures
    Cloud cover made getting some of the sun shots difficult (luckily it would clear up at the very end)
  3. zspectrum
    zspectrum Jedi Nuba
    Looks absolutely stunning. Supernatural has shown to be a real contender with the big names like Swissvax and Zymol.
  4. Dust2Glory
    Dust2Glory Nuba Guru
    My first thoughts excatly... simply stunning!!! that red is so deep and rich it's crazy!!! awesome save and excellent finish
  5. Charlies02GLS
    Charlies02GLS Jedi Nuba
    Great job!
  6. MWAUTOPRO
    MWAUTOPRO Jedi Nuba
    Great work and an awesome car. How long did you soak the unigritt prior to using it?
  7. bigpoppa
    bigpoppa Jedi Nuba
    Mmm, I'm not really one for Ferraris, but something about the shape of the Testarossa just does it for me. Awesome work! :)
    I'm guessing you polished the louvers by hand?
  8. Todd
    Todd Banned
    I personally love it but then again I think A LOT of waxes compete with Zymol and Swissvax.
    Thanks!
    Thank you!
    About an hour or so. Thank you for the compliments MWAutopro
    Thanks poppa. I actually had detailed this car a year about (a little less then a year) so some areas such as the stakes where in great shape. A little bit of Lime Prime and elbow grease on one of my custom cut LC White Foam applicators did the trick nicely this time around.
  9. Ivan Rajic
    Ivan Rajic Any Rag Vehicle Washer
    My favorite Ferrari... Great work! Can't beat properly polished Ferrari red!
  10. GBS
    GBS Wax on..Wax off
    I always loved the Testarossa. The colors in the pictures don't look natural.
  11. Cooter
    +1 with GBS's comments. Looks stunning!! Awesome work!
  12. slanguage
    looks great. awesome work!!
    What was under the car cover at the end of the driveway?
  13. zoomzoom mazda5
    Awesome save on the Ferrari, looks super wet!:worship2:
  14. Todd
    Todd Banned
    Thanks Ivan
    Awesome cars.. The colors are SUPERnatural (or the white balance was off on the D40X) :p
    Thanks Cooter
    Its a Diablo
    Gracias mi amigo :D
  15. sal329
    sal329 Nuba Guru
    :worship2: Great job :thumb:
  16. Deep Gloss Auto Salon
    What can I say.. yet another solid piece of work By Bella Machina!!!
    Glad to see you have found a spot in your bag if tricks for Supernatural, it reall is a fine offering!
  17. bryansbestwax
    I am a lambo fan but that is one of my all time favourite sports cars.
