Ferrari 458 Speciale MAJOR Paint Correction & Gyeon Quartz MOHS+ Coating System
Discussion in 'Professional Detailer's Studio' started by Gyeon_Jeff, Dec 17, 2015.
  1. Gyeon_Jeff
    Gyeon_Jeff New Member
    Vehicle: 2016 Ferrari 458 Speciale
    Gyeon Quartz Certified Detailer: Detail Force, Inc Denver CO (www.DetailForce.com)
    Project: Gyeon MOHS+ New Car Protection Package
    So how bad can the finish on your brand new, $430k, custom ordered Ferrari 458 Speciale be when you finally take delivery?....well....very very bad.
    An EXTENSIVE paint correction process was performed to repair all the damage done by an inexperienced high speed polisher user somewhere along the line. The defects in the paints finish were intense and robbing it completely of it's true color, depth, and gloss.
    Once corrected, the Gyeon Quartz MOHS+ (Certified Detailers Only) Ceramic Coating system was installed for an incredible shine, long term protection, and the ability for the paint to shed water and contaminants very effectively to preserve the finish for years to come.
    The Mohs+ system was then cured with our InfraRed curing lamps to achieve maximum gloss and hardness. What a huge turnaround on this very special project.
    Along with the paint, Gyeon Quartz Rim was used to protect the wheels, Gyeon Quartz View on the Windshield and Glass, Gyeon Quartz Tire for the tires,and Gyeon Quartz LeatherCoat and Gyeon Quartz FabricCoat for the interior surfaces.
    The Process:
    1. A thorough wash using Gyeon Quartz Bathe
    2. Medium Clay Bar Process to remove the Above Surface Bonded Contaminants from the finish with Gyeon Quartz Clay Lube and Medium Clay
    3. A good soak in Gyeon Quartz Iron to remove the Below Surface Bonded Contaminants
    4. Gyeon Quartz Iron is also used on the Wheels to remove all Iron Ferrous Particles and give them a deep clean
    5. Tape all trim and possibly dangerous edges to protect them from polishes and machines during paint correction
    6. Using the full range of Rupes Polishers we remove all swirls, holograms, buffer trials, and marring from the paints finish
    7. Give the paint a thorough wipe down in Gyeon Quartz Prep to remove all polishing oils to ensure a pure surface for coating
    8. MOHS+ Time!!! MOHS+ is only available through Gyeon Quartz Certified Detailers. To see a list of installers visit http://gyeonquartzusa.com/web/contact. MOHS+ utilizes a base coat and top coat system to provide incredible gloss and hardness, while creating the ability of the paints surface to SHEET water more than bead. This allows for increased protection from water spotting and chemical etching.
    9. All Gyeon Certified Detailers use InfraRed Curing Lamps to get the most gloss and performance out of the system
    10. While IR Curing is taking place we move on to the Wheels with Gyeon Quartz Rim
    11. Gyeon Quartz View is installed on the windshield and glass to repel water very effectively during bad weather. Gyeon View is also a 2 part system where a bonding agent is applied to the glass prior to the actual SiO2 based coating. Very effective
    12. Once the Wheels are done we move on to the interior with Gyeon Quartz LeatherCoat and Gyeon Quartz FabricCoat
    Now for some Photos!!
    As you can see...TONS of work to be done here. Some initial outside inspection shots.
    Hologram and Buffer Trail City
    OUCH
    Inside now for further inspection and to begin polish work. No Decon and Prep photos :(
    After Compound Stage with Shine Supply Classic Cut. A bit hazy and in need of some fine finishing.
    There we are
    More polishing
    The Tail Lights were in need of polish work as well
    Now the Party is Starting !! MOHS+ Time!!
    MOHS+ is an extremely easy to apply, quick initial bond, coating system that is very easy to work in and remove
    After application MOHS+ is IR cured for maximum hardness and gloss
    After......
    Outside Shots. What an incredible glow this car has..
    Yes the bumper was a slightly different color. Gotta love Ferrari OEM paint standards
    No more beat up side mirrors!
    Thanks for checking out the project! For more info on Gyeon Quartz and our Certified Detailer Network contact either Phil at Detailers Domain or Jeff at Gyeon Quartz USA. Thank you!
    Francisco Santiago and punk0208 like this.
  2. detailersdomain
    great job!
    anyway you can size those photos ; )
  3. AutoNuvo
    AutoNuvo Member
    Nice Jeff!
  4. Mbkite
    Mbkite Member
    Great work on a good looking car post 1 up with can coat on it..
  5. denobd
    denobd Virgin Detailer
    beautiful machine... great job.
  6. Francisco Santiago
    Francisco Santiago Virgin Detailer
    Amazing work Jeff. SHOW!!
  7. GDAL
    GDAL Super Moderator
    That's a great transformation ... those buffer trails were definitively an eyesore!
