Does anyone know where I can find a tripod for my TK11??? my garage space is very limited and I like a small tripod for my TK11 to hold it in place while im detailing. Thanks
If you plan on using any LED light as your constant lightsource for correction you better be made of money, Fenix's burn through batteries pretty fast... and thats using them simply as a spot light where its on for 15 seconds to check the finish then off. Use halogens for a steady light-source for polishing, they stay on for a very long time and when the bulbs burn out just replace them, should only cost you a few dollars per bulb.
yeah but halogen is too bulky for my garage, even a handheld one is bulky. heres a BMW 3 series in my garage n parked a little bit closer to the other side.
There is a head attachment for fenix torch actually, but because fenix light has a hot spot so might not be ideal to use for close range.
Lowes has a LED headlamp that has 175 lumens for about $50. Single LED light...4 watt I think. It is very bright and has a dimmer switch to adjust the brightness. Just bought it and have not used it while polishing yet. The light fixture and battery pack are pretty small and light. Smaller than the looks of the Apex Pro headlamp linked to above. I think I will need to wear a baseball cap underneath or the straps will be irrating.
