Does anyone know why my pics are in an album like that instead of just laid out 1 after the other like everyone else's? Sorry new here.
Dude you can't post on here without telling what products you use!!!! I'm sure that's in the rules somewhere!
I don't want to get in any trouble. I'm somewhat new to forums and haven't yet heard anyone mention the products I use. Car Brite is where I purchase most of my interior cleaner. For example I use extra duty aerosol foam to clean leather. works wonders. Thx for the tip on the photos
Like I said, I'm knew to forums, so I just wrote that cuz I'm not 100% on all the "rules" yet. With this paying to advertise and no company names and stuff without paying to advertise.
We have pretty much free speech here when it comes to products. No linking unless requested by another member but you can talk about your favorite products all you like and I assure you many on here will do the leg work on the internet to find them if they want them bad enough. As you read on here you will see probably the largest multitude of products used/discussed than on any other detailing forum.
Is the product you are referring to. E006 XTRA DUTY AEROSOL DESCRIPTION: A white, aerosol, general purpose cleaner that is mint scented and safe to use since it contains no Methylene Chloride. Its dry foaming formulation effectively cleans vinyl, leather, rubber, plastic and fabric surfaces without soaking in, which minimizes drying time. KEY FEATURES: • Dry white foam • Contains no Methylene Chloride • Ready-to-use • Contains solvents & fortified surfactants • Mint scented KEY BENEFITS: • Formulated without Methylene Chloride to ensure worker safety • Dry foam does not saturate surfaces which minimizes drying time • Fortified surfactants loosen and lift dirt and grime • Specially formulated solvents dissolve grease and other petroleum-based contaminants • Extremely versatile product - effectively cleans vinyl, leather, rubber, plastic, upholstery & carpeting HOW TO USE: Interior Vinyl, Leather, Rubber & Plastic Surfaces 1. Shake container well before and during use. 2. Spray product directly on surface to be cleaned, holding container 6 to 8 inches away from surface. 3. Dry area completely with a clean towel. Interior Upholstery & Carpeting 1. Shake container well before and during use. 2. Thoroughly vacuum area to be cleaned. 3. Spray product directly on surface to be cleaned, holding container 6 to 8 inches away from surface. 4. Lightly scrub surfaces with a sponge or upholstery brush. 5. Blot dry with a clean towel. 6. Thoroughly re-vacuum areas cleaned. • Do not allow product to dry on surface. • Consult the Material Safety Data Sheet (MSDS) for complete safety information
Cool thanks for explaining and in that case.... I use mostly Car Brite products they do the job for me I spot treat all stains with See Spot Go, then hand shampoo the carpets from front to back with Blue Max all purpose cleaner. I find it take the stains out 99% of the time.
