Engine Detail Protectant?
Discussion in 'Car Detailing Product Discussion' started by mrd0t, Dec 3, 2011.
  1. mrd0t
    mrd0t Obsessive Detailer
    Which one would you choose? Looking for a Low Sheen finish and protection for a engine detail on Monday. I only have acess to these two or any other available Otc... AG Vinyl & Rubber Care or Vinylex by Lexol
  2. Meticulous-Detail
    I say AG Vinyl and Rubber. I personally use Megs WBD on my engine compartment. Here is a pic:[​IMG]
  3. Kilo6_one
    I used Megs Hyper dressing, you can dilute it to taste.... from glossy to matte.
  4. lasthope05
    lasthope05 Jedi Nuba
    AG VRC. Good darkening effect and gives it a nice sheen(smells great). Vinylex is pretty glossy.
  5. 911Fanatic
    AG. After rinsing the motor, spray it down with the AG VRC and let the motor run for about ten minutes. The dressing will dry to a nice sheen.
  6. mrd0t
    Thanks everyone....I will be detailing a 650Hp R32 tomorrow and wanted to get it right. 911Fanatic, the motor should not be too filthy and will probably just require a degreaser worked a section at a time and towel dried, then AG applied. Will it work the same if the engine bay is dry and it is applied then have the engine run? Will it created a different look? Or does it have to be wet?
  7. 911Fanatic
    Should get the same look. Its just convenient if had to shampoo the motor, you don't have to dry it first before applying. If you have one, use a trigger with adjustable tip to get a finer spray. The AG one tends to shoot a heavy spray, wasting product.
  8. mrd0t
    Thanks for the advice...now to find some spray bottles locally...lol.
  9. Danny
    Danny Nuba Guru
    I do what Ken does but just use 303 Aerospace protectant in place of AG VRC. Both give a great look and dry nicely into the surfaces.
  10. GDAL
    GDAL Super Moderator
    I use Adams In and Out with great results.
  11. mrd0t
    Compared AutoGlym Vinyl &Rubber Care with Adams Super VRT.
    Surface was precleaned with degreaser and let to fully dry before applying one layer of dressing.
    AG ended up with more shine as Adams was more matte IMO.
    What do you think?
    Note: AG V&R Care's spray bottle shoots a thick amount, might be better to spray on applicator then spread.
  12. yamabob
    yamabob Two Bucket System Washer
    being the greenie I am,if you were presenting that to me as a customer -I would prefer the Adam's
  13. Kilo6_one
    adams looks far better........
  14. WashingJosh
    WashingJosh Jedi Nuba
    I've been meaning to try out Duragloss 265. I never seen anyone talk about it on here (maybe for a reason).
    If it works like Adam's in and out, I'd be really happy because of the price difference.
  15. Meticulous-Detail
    I have read good things about DG 265 on other websites and would like to see a comparison with Adams In and Out.
  16. mrd0t
    I prefer the look of Adams after my comparison. I can see where AG can become useful since its a liquid form, but I don't like how cheap and greasy it looks similar to this guys details...lol.
  17. lasthope05
    Did you buff it down? It definitely isnt a greasy shine like the last pic you posted above. Also you can dilute the product 1:1.
  18. mrd0t
    I did not buff it down, just spread it with a clean applicator. Did not know I could dilute it...with distilled water?
  19. lasthope05
    Its not advertised as dilutable but it can be with regular water, its a dressing and not a qd so purity doesnt matter. The professional version is a concentrated version hence its ability to be diluted and it being water baased. Also on the back are basic instructions for both high sheen and low sheen. For high apply liberally and allow to soak a few mins before lightly going over with a towel. For low sheen, apply sparingly and remove with a cloth right away.
