Does DWG need any curing time before topping with a sealant ,wax or something like wet mirror finish ?
Dogma...you can do it right after you apply it..but I wait like a hour if I have time and then apply a topper..reason is I let it completely air out any dryers on it before I use a topper....once and only once I had a problem doing a topper right away..but it was humid out..so it was not flashing off fast and the topper was smearing..so I wait if I can for it to flash all off and then top...if it is dry air you should be set right after... Al
Though it has no curing time, sometimes I like to wait about 30 minutes before applying another layer or another LSP, not because it is necessary, but somehow it just makes me feel better about the process.
If you check on CG's site it says "A one-step surface preparatory product " That leads me to believe it has some cleaners. I haven't used the stuff though so I'm not sure.
