dsms detailed - Dull Acura Restored
Discussion in 'Professional Detailer's Studio' started by dsms, Oct 22, 2008.
  1. dsms
    dsms DB Forum Supporter
    This one was in pretty bad shape. The owner called me and said his paint was "dull" and asked if I could bring back the shine. I said the only way to fix dull paint is with machine polishing and that no wax or sealant will bring back the true finish of the paint unless its fully corrected and polished properly, he wanted this car fixed up so he could sell it. Upon getting the car I saw it needed some extensive correction work.
    The sun was just coming out so I tried to catch some swirls while I could
    The trunk was by far the worst part, ater under the halogens you will se the amount of deep RIDS
    When I say "dull" this is what I mean, the car needed the gloss brought back in a big way
    After cleaning the wheels, I washed the car using the 2BM and 2 white foam shmitts with Gloss Shampoo. The gloss shampoo is very mild and wont strip an LSP, since this car had no LSP anyway there was no need for a citrus based shampoo.
    After washing I clayed the car with gloss it lavender clay (agressive) using Meguiars last touch 1:1 as lube. The car was mildly contaminated.
    Now for the correction work. I worked a small portion of the hood as a test panel using the Makita at about 1500rpm with a Meguiars cutting pad using the Gloss It 1 step polish. This yielded about 70% correction but the deeper scratches werent touched so I stepped up to the gloss it 8" lambswool pad and gloss it extreme cut compound. I worked it at 1500rpm and jeweled it down to about 1000, I then followed that up with the gloss it 1 step machine polish on a foam polishing pad.
    The 8" lambswool pad, I like it because it has enough cut to polish out deeper defects but its not as coarse as some of blended wools out there. The hologramming was very minimal after jeweling down the extreme cut to about 1000rpm, I added some of the gloss it QD during the polishing stages to get more work time out of the compounds and polishes.
    Here is a 50/50
    Some finished shots after polsihing at the IPA wipedown...
    After polsihing only, no LSP
    Now onto the biggest problem area...
    Some very deep RIDS and coarse swirls, i measured the paint with the PTG to see how much clear I had to play with...averaged 170-185microns which was plenty.
    I went for the extreme cut right away
    Before
    After 3 passes at 1500-1800rpm using the extreme cut, I kept working the polish by spraying the gloss it QD in between..this helped reduce holograms as well
    I then followed up with gloss it 1 step machine polish on a burgandy megs cutting pad at 1500rpm
    This brought back the gloss after compounding
    Some 50/50's
    All finished
    The rest of the trunk section was totally flat and heavily swirled as well
    Before..
    During..
    After..
    No correction job would be complete without a sun shot, I pulled the car out to inspect my work
    Next I moved onto the side panels, the paint was very flat. I used some gloss it extreme cut at 1500rpm with a megs cutting pad and then followed up with the cyclo with the 1 step polish.
    Here is a before and after of how the depth and clarity was restored
    After finishing with the cyclo
    After polishing the extreme cut at 1500rpm, defects removed with slight hologramming
    I then followed up with the cyclo using yellow polishing pads, I can work much larger areas with the cyclo not having to tape off edges and breaking panels into 2 parts
    working the 1 step polish
    after, a deep hologram free finish
    RIDS before
    After
    Before applying the LSP after polishing I like to do all the finishing touches. I went and applied gloss it tire dressing, admas undercarrige spray to the wheel wells, cleaned the glass and exhaust tips and then treated the plastic trim.
    Here is the lower plastic trim faded and spoted, after cleaning with IPA solution to remove any grease
    After
    I brought the car outside even though the sun was going down and then I had a nice suprise pull in my driveway
    My favorite customer stopped by to show me his new GTR and to see what kind of work it would need to get it ready for winter, because this one aint staying in the garage! Im doing that one on Halloween.
    Some finished shots before the sun went away for good. The LSP was gloss it gloss finish sealant applied by hand via red foam pad
    Dullness be gone
    Here is the paint before
    And after
    Thanks for looking and hope you enjoyed :mounty:
  2. Hum-Benz
    Hum-Benz Wax on..Wax off
    Great work!
  3. Buddy
    WOW, Beautiful detail. What a change. I can't get over how good it looks. How much time did spend on it? was it just ext?
  4. milabfocker
    milabfocker Jedi Nuba
    Ridiculous 50/50s; awesome work.
  5. Denzil
    Amazing turnaround! Glad you were able to save this vehicle, hehe.
  6. svpro
    svpro Birth of a Detailer
    It is amazing.....that you can bring the car back to showroom condition
  7. slanguage
    looks great. awesome job all-around, and nice color too :thumb:
  8. Scott's Mobile Detailing
    awesome job man!!!!
  9. carnut00
    carnut00 Virgin Detailer
    Hell of a job. Looks great.
  10. bewilliams14
    bewilliams14 Any Rag Vehicle Washer
    great 50-50 shots, car looks awesome
  11. dschia
    dschia Jedi Nuba
    Nice make over, how much time did you take for the job?
  12. kenny1775
    kenny1775 Jedi Nuba
    Amazing work and excellent recovery on that RL :applause:
    Looks like I now have yet another reason to consider buying this Gloss-it stuff:duh:
  13. TexasTB
    TexasTB Obsessive Detailer
    Very Nice work:applause:
  14. richy
    Very, very nice work!!! That's a cool stool you've got there too. I LOVE the GT-R!! And in red too..OMG, I can't wait to see that one done!! Colour makes all the difference on a car. I'm used to seeing them in ugly silver and the like..wow does red make it jump...can't wait to see when you're done with it.
  15. tdekany
    tdekany Wax on..Wax off
    Fantastic work man!!!!!:thumb::thumb::thumb:
    Now the owner just need to get new hub caps.
  16. Smith2287
    Wow great work on that car, you really did it justice. After seeing those 50/50 shots I wan to give the gloss it lineup a try myself. I am going to look into their product line what do you recommend from them?
  17. Duratys
    Duratys Welcome to Detailing
    Who dosent love 50/50s ...... Very nice work on that one :applause2:
  18. supercharged
    very well done!!!
  19. pirex
    pirex DB Certified Dealer
    Very nice :D
  20. dsms
    Thanks, I would say most of the car came out at least 98% defect free. To fix the deep scratch on the trunk I would have needed to sand it with 1500 or 2000 grit. The owner asked me to do all I possibly could to restore the finish without wet-sanding the paint so I left it alone. This car was restored to sell, the owner wanted to keep the price of this detail down so he didnt ask for an interior job (even though it needed) or for some of those scratches to be sanded. Overall I think the finish really came back to life, and I think this deep green is a really nice color.
