dsms detailed - 08' Porsche 997 Turbo...
Discussion in 'Professional Detailer's Studio' started by dsms, Jul 9, 2009.
  1. dsms
    dsms DB Forum Supporter
    This was my first full mobile detail in 8months, packed up the car and got to it.
    During the wash process, the car had almost no protection but a lot of old shampoo was rinsed out of the cracks.
    Washed w/ GI gloss shampoo. All emblems, cracks and crevices were agitated with APC 10:1. The ragtop was cleaned with, raggtop.
    Wheels were cleaned with GI wheel gel at 4:1 as they were not very dirty and the tires were scrubbed with ARO and Tarminator
    Pulled the car inside for claying, GI fine clay and Megs LT were used. After which the car was wiped down 2 times with IPA to prep for polishing.
    While the engine was still a little wet from the wash I cleaned it up with APC 10:1 on a damp MF, later everything was dressed with P & S express interior cleaner which left a simple matte look on the plastic and trim pieces. All door jambs were cleaned with the APC as well.
    After
    Tips polished with Noxon using #0000 steel wool on the chrome and #00 steel wool on the inside, then polishing again with just an MF
    Raised up the rear wing again after the wash to polish out the poles
    Correction was nothing major at all, only a few stops needed several stages of polishing or wetsanding . The car is still fairly new so a 1 step correction was agreed on with the owner for most of the car, except the few problem areas
    GI one step machine gloss
    GI EVP pad prime
    Flex 3403
    I spread GI OSMG at 1100rpm, corrected at 1500rpm for several passes and backed down to 1100rpm again to finish and then jewel the paint.
    Problem area #1, wetsanded with 2500 unigrit and corrected with GI extreme cut and a 4" tuf buf wool pad, followed by OSMG using orange and green pads.
    Before
    During
    After
    Short polishing video. I already spread the polish at 1100rpm so here im working at 1500rpm with the EVP. I start off with faster passes and as I reduce speed I slow down and refine the finish
    One of the few things louder than the drone of a Flex 3403 pulled in the garage too
    Problem area #2, this guy was a little deeper and needed 2000 grit followed with 3000 to fully remove
    Few hairline scratches were underneath the Turbo emblem, corrected with an orange cutting pad and GI extreme cut
    After correction started with some trim treatment. Front lower lip was a little dry and worn. I applied GI TRV dressing with a foam foam painters stick
    50/50 with TRV dressing
    Before I started on the rear seats I had to remove them and let them sit under the halogens for a bit to soften up, its thin leather backed by thick plastic so cleaning them properly was a little tricky before the leather softened up. (nice thing about porsche rear seats is that the are attached by velcro so they just pop right out)
    Tidied up the cargo area. Seals and plastic dressed with TRV as well
    After TRV
    Laid down the first coat of GI tire gloss and let it soak for 10minutes and then buffed it in
    Rear mats were a little dirty but the stains lifted fairly easy with Folex, some agitation and a wetdry
    Before
    After
    The rear buckets were cleaned with GI satin leather cleaner, followed with the satin leather polish and placed back in the car.
    I folded down the back seats and vacuumed there... to be honest there was barely any dirt back here but doing a quick once over with the vacuum lets the owner know you have been there... chances are they will never check but if they do you will be glad they see it!
    LSP:
    GI Gloss finish x1
    GI Concourso Gloss x1
    I let the base coat of Gloss Finish cure for 30mins and buffed off before applying the concourso, both were done by hand with LC 100ppi hand apps
    After removing gloss finish
    While the Concourso was curing I moved to the rest of the interior... one of the many crevices with old wax residue
    Under the seats were the 2 usual items, empty water bottle and a plastic bag but also a brand new rolling stones CD :confused:... finding stuff like this means brownie points from the owner! "Oh I have been looking everywhere for this" :lol:
    Cleaned up the rubber roof lining for the ragtop
    When I removed the rear seat buckets there was some crumbs and stuff underneath, quick vacuum here
    Interior:
    GI satin leather polish
    Folex carpet cleaner
    Afters
    Odds and ends:
    Glass cleaned with Surf City clearly better (so far a really great product)
    Wheel wells dressed with Adams
    Ragtop protected with Raggtop protectant
    FK 425 wipedown
    Pulled it outside for some shots before the final wipedown
    2 coats of GI tire gloss, wheels sealed with Rejex
    Back inside
    My next project for August, I think its a boxster
    One more...
  2. J BELL
    J BELL Nuba Guru
    Great job david, i like the video too. I need to kick it up to a rotary...anywho, i always enjoy your work.
  3. Stems
    Stems Birth of a Detailer
    Awesome, looking forward to that Carrera GT.
  4. mrgolfrider
    Nice work as usual David...do you hate doing the mobile details?
  5. michakaveli
    Thanks for posting!
  6. RNickolas
    RNickolas Obsessive Detailer
    LOL@boxster comment...everyone knows its that new four door porsche
  7. dionnfr
    dionnfr Birth of a Detailer
    Excellent job, pictures told a story.
  8. dsms
    I have been a little spoiled by my garage (air conditioning and lots of lighting) so mobile details are something I dont look forward to. The nice thing however was the garage space i had to work in was even bigger than mine, but to balance it out I had a single overhead light which came from the garage door opener! That made cleaning the interior and viewing paint a little tricky so I had to drag my standing halogens everywhere I went.
    I do prefer to work in my own garage/controlled environment though.
  9. Jayplay
    Jayplay DB Pro Supporter
    nice work fella
  10. Nica
    Wow gorgeous garage :thud: :thud: I dream of a garage like that one day I'll have it and filled with nice toys too :woo:
    Vehicle looks great well done :thumb:
    Hahaha nice one on the boxter :lol2:
  11. detaildoc
    detaildoc Guest
    Great job man. How do you apply your GI Tire Gloss? Do you spray it on and let it sit, or do you apply with an applicator?
  12. Smith2287
    Great job man on the P car thats another luxury4play car isn't it. I think I have seen the gt at the last rally I attended with these guys. You do some outstanding work buddy!!
  13. fricker66
    fricker66 Birth of a Detailer
    Wow, great job on the detail. I'm sure you're looking forward to that "Boxster" detail... Is the Ferrari on the project list as well?
  14. richy
    Boy you got the Porsche looking great! Nice client to have. Those cars..its like getting to massage a pretty woman....
  15. 911Fanatic
    Beautiful job David!
  16. P1et
    Just lovely work mate!
  17. dsms
    No, its not like getting to massage a pretty woman.. they are machines, yes beautiful and fun machines but I treated this porsche like any other car I detail. :thumb:
  18. akeller503
    akeller503 Virgin Detailer
    Love your threads, great work on the car!
  19. kustomizingkid
    kustomizingkid Nuba Guru
    Amazing work as always
