dsms detailed - 08' Obsidian Black Pearl Subby STi
Discussion in 'Professional Detailer's Studio' started by dsms, Dec 18, 2008.
  1. dsms
    dsms DB Forum Supporter
    The was a partial new car prep on this 2008 Subaru STi. The car had about 800miles on it and recently had some clear bra work done to the side fenders and lower body panels.
    On with the detail...
    Before pic, this is about 9am Saturday morning. It was well below freezing temps here in NJ and I saw all the water froze on my driveway during the pre-rinse and wheel cleaning steps. Thats when I knew I was going to ONR this bad boy inside the garage instead of using my normal sudsy wash routine outdoors.
    As usual I started with the wheels, in this case some very spokey BBS'
    Before
    I used the P21s gel on these wheels to ensure no damage to the finish or more importantly the brakes, I let the gel dwell for about 10mins after the initial pressure wash using the Cam spray
    I used an assortmant of brushes to get in every crevice of these intricate wheels.
    boars hair brush
    swissvax brush
    wooden spoke brush (for the inner barrels)
    oxo tire scrub brush
    black agressve shmitt for the wheel wells
    Heres me using the boars hair brush for the initial agitation of the p21s, this brush is great for wheels such as these. I used to just use the swissvax brush to go in and out of every spoke but now I can get about 85% of the wheels clean much faster with the large bristles on the boars hair brush.
    I then cleaned the inners with a long handle spoke brush and re-worked all the spokes with the much more precise swissvax brush. Calipers were scrubbed as well
    Tires/wells were scrubbed using APC 4:1
    After
    Another before, you can see the caked up brake dust settled in all the ridges of the wheel
    After
    Inners all squeaky clean
    I then proceeded to thoroughly rinse the paint finish
    Followed by a p21s TAW pre-soak
    While I let the citrus soap dwell on the paint I used a designated siwssvax wheel brush to agitate the emblems and trim
    I rinsed the car once more...adding to the thick layer of ice forming beneath my feet due to the freezing temps and pulled the Subby inside for the ONR wash.
    The fact that this car has 4wd gave me some piece of mind pulling it in the garage, it was very icy on the driveway that morning!
    With the car still wet I used the 2 bucket method and began to ONR wash the car panel by panel using soft foam sponges from DD, there just like the Zymol sponges I used to have and work very well with ONR solution
    ONR working its magic
    I dried each panel with CG miracle dryers and moved onto claying
    Sonus fine green clay was used. The car still being new I felt there was no need to use anything more than a soft clay, as I expected the car was only lightly contaminated
    Last touch QD 1:1 was used to lubricate the finish while claying
    After claying I measured the paint using the PTG and began my inspection starting with the hood
    The owner informed me he attempted to clay the car but unfortunatley the clay picked up a large particle or something which induced some heavy scrtahces on the hood scoop area.
    These deep RIDS needed the use of an agressive polish/compound to remove where as the rest of the hood needed a lighter corrective polish
    Heres what I mean.
    Using the Fenix TK10 to show defects is a great tool for paint inspection, especially on metallics. Big thanks to Bob at Auto Concierge for introducing me to this little light. I cant do paint correction without it now!
    Now under the standing halogens
    I used Gloss It extreme cut on the cyclo with orange pads to cut out the defects and then followed up with the Evolution polish to refine the paint and bring out that last bit off gloss.
    The result
    I corrected the rest of the paint usning the Gloss It one step machine polish on the cyclo with green pads
    The result after only 1 step, later the finished was jeweled on the makita
    Remember that scratched hood scoop?
    This is the final shot under the same Fenix LED light
    I then corrected the rest of the car
    drivers side rear quarter before shots, swirls and light RIDS
    After correcting the paint with the gloss it 1 step machine polish on the cyclo with green pads (15-20lbs of pressure before letting up to refine the finish was used on the cyclo)
    The paint at this point was just about perfect and finished down 100% LSP ready. I decided to go one step further and I broke out the makita for some extra jeweling.
    On the makita I used 3M Ultrafina with the Gloss It EVP prime on a blue lake country finishing pad.
    Ultrafina seems to always leave a clean finish but it never really adds gloss or depth IMO on a finish that is already leveled and defect free but UF is just so damn consistant I decided to use it anyway.
    I used the EVP prime on the LC blue finishing pad to allow me to repeatedly jewel and burnish the clearcoat to a very wet, deep finish. What the EVP does in addition to lubricating your pad is disperse heat. On the makita i wash polishing at about 1400rpm max but I was not limited to how long i could work the product. The EVP allows you virtually unlimited work time of most polishes. I kept burnishing down the finish till I got 900rpm and then I did some last slow passes.
    The results of an extra 3hrs of jeweling the paint was very rewarding. I managed to bring out a deeper, wetter looking finish before even applying the LSP.
    Here are some post polishing shots after jeweling and an IPA wipedown
    The hood, defect free under the infratech
    No LSP yet
    The sun came out for a few minutes so I brought the car out after polishing, again a no LSP finish is shown here
    The plastic undr the winshield was treated with Gloss It TRV, the trim by the windows was treated with 1Z gummi pledge. Exhaust was cleaned using Noxon
    I brought the car back in for the finishing tocuhes including LSP application.
    The LSP combo of choice was the following:
    2 coats of Gloss Finish applied by hand (cured 15mins each)
    1 coat of Gloss It Concourso Polish by hand (cured 30mins)
    While the LSP's were curing I went on to clean the glass, trim and dress the tires etc.
    Here is the Signature tire gloss soaking into the rubber while gloss finish cures
    Tires dressing fully soaked in and lightly wiped off, the flash gives it some more shine but in the next pics you will see how it looks in daylight, very natural
    Doing my final walk around I spotted some dried polish in the front grill so I took out my little detail swab...
    Now for the afters...
    Finished
    The depth and clarity came out very nicely, the hood had one of the most glassy reflections I have seen yet
    Of course the sun was no longer but the finish still popped under the clouds
    Heres the tire dressing in natural lighting
    Last one...
    As always thank your for letting me share my work with you, hope you enjoyed! :thumb:
  2. trhland
    trhland Nuba Guru
    :worship2::worship2::worship2::worship2::worship2::worship2::worship2::worship2::worship2:
  3. J BELL
    J BELL Nuba Guru
    Wow, that is a great looking STI, ur work is some of the best and i always look forward to your posts, nice job as always
  4. krshultz
    krshultz Nuba Guru
    That is some excellent work!
    I've got a question for you. On cars like this, there is often very little clearance between the outer portion of the brake caliper, and the inner portion of the wheel. Sometimes it's not much better around the perimeter of the brake rotor. How do you get the wheels so clean on the insides?
    The last one I did was a Dodge Ram, and it had the same kind of thing - almost no room between the brakes and the inside of the wheel. With a normal car, I could just take the wheels off - that's easy enough - but I don't have a big enough jack to get a quad-cab Dodge up into the air.
    Thanks for any input.
  5. virtual
    virtual DB Pro Supporter
    That looks awesome, great work! :)
    Have to try some of the Gloss It products..
  6. Duratys
    Duratys Welcome to Detailing
    Very impressive work :thumb:
  7. P1et
    Incredibly wet Scooby!
  8. slanguage
    Nice write-up and awesome job :thumb:
    I use the sv brush to do the trim/windows etc also.
    I do agree the ONR works great with the DD sponges.
    Black has the best reflections of any color when done right, and this detail is proof!!!
  9. Buddy
    Beautiful Just Beautiful...:thumb:
  10. krshultz
    krshultz Nuba Guru
    Wonder if the owner has had to replace the engine in his yet...
    A bit of an OT aside. As I think you guys know, I autocross. Subaru STIs are in "A Stock" with my S2000, and this year, some of these new 5-door ones started to show up. Nearly all of them, at some point, had to have their engines replaced - one at like 700 miles.:yikes:
    Turns out it was a bug in the engine computer. When you run the engine on the rev limiter - which happens often in an STI, since they're geared so short - the engine starts to run very lean, and eventually, the engine fails.
    There's a reflash now available for the ECU that fixes it. If this guy has any intentions of autocrossing his STI, he should go to the dealer, and have that done.
  11. SHhhhh
    SHhhhh Two Bucket System Washer
    Awesome detail work! The car came out great. How many fluorescent lights do you have in the garage? Seeing the florescent's in your pics remind me how bad the lighting is in my garage!
  12. zspectrum
    zspectrum Jedi Nuba
    smoke? Im trackscoob19 on iwsti.
  13. DLR Detailing
    DLR Detailing Jedi Nuba
    Very nice work on the Subaru! :applause2: I really like the paint! :headbang: Thanks for sharing with us.
  14. Pats300zx
    Very nice job. Considering the conditions you had to work in I think the car came out incredible...:worship2:
  15. 911Fanatic
    Very nice looking job! How do you like working with the Gloss-it products? I know they are made to work with a dual action machine. Does it cut just as quickly as a rotary?
  16. dsms
    What about if the conditions I had to work in weren't bad? :shead:
    j/k thanks Pat
  17. ScottieB
    ScottieB Jedi Nuba
    The first bumper pic with you in it, is a great shot. Well done!!
  18. BrendanS
    BrendanS Welcome to Detailing
    that looks great, the tire dressing looks really good to. Probably one of my favourite looks, not to greasy looking, just right. How long does it last you?
  19. scheerspeed
    very nice job!
  20. racersky
    racersky Jedi Nuba
    Wow.....i definitely gonna try and get some of that ONR. Our area sucks. When it's cold it's freaking cold Northeast Region for the lose lol
