This one needed quite a bit of work, unfortunatley the owner did not want any correction or polishing done to the car and needed it back the same day. The A8 arrived at my house around 8am Sunday. It was a chilly 50degree morning here in NJ that day...the last car I worked on was in 80+degree weather, just one week prior. Here is the inital condition of the car upon drop off I inspected the Audi and saw lots of road grime on the lower panels and tons of dried bugs on the front end. After cleaning the wheels using PoorBoys spray and rinse in conjunction with the swissvax and EZ wheel brushes I moved onto washing the Audi. My wash process was as follows: Pre soak w/ P21s TAW Treat all dried bugs with Poorboys bug squash 2:1 (superb product) Treat all lower panels road grim with Surf City road grime destroyer(new favorite) 2BM using Gloss It Gloss shampoo (slicker than Z7, highly concentrated) Here are some shots of the lower panels Before surf city road grime destroyer During After Before I must thank Todd Helme for the reccomendation of this product. I saw his thread about a orange gallardo which had very similar road grime/tar that was taken care of with the grime destroyer from surf city. Overall I really think this is a great product to have in your arsenal, its a very think gel that you spray on and let dwell before some light agitation and it works like a charm. Also the PB bug squash is great, similar application but its much thinner consistancy and it really loosens dried bugs on the paint. Next came claying. I used Gloss It green clay(mild) with megs last touch 1:1 as lube. The gloss it green clay is very smooth and for a mild clay it picks up a lot of contaminants n 1 pass. Here is the clay after only 1/2 the hood:shakehead: I clay only 1 panel at a time and then re-wipe the panel using the last touch lube to avoid re-washing the car to remove the clay/lube residue After clay I moved on to the "less than stellar" interior. I used Gloss It satin leather cleaner for all leather care, its by far the best leather cleaner I have used. Its as easy to use as Lexol or Zaino stuff but it has the cleaning ability of Leather Masters...the best part? No streaking! Passenger seat before cleaning Passenger seat after cleaing 50/50 What looks like body oils from leaning on the arm rest Scuffs and stains on the interior lower panels Before During After I then turned my attention over to the carpets. After dry brushing and vacuuming I pre treated the stained areas with Folex solution and then pressure washed the carptes to remove the deeper stains. After PW'ing the carptes I used APC 10:1 and agitated for several minutes followed by another PW rinse and then drying in the sun. Before, all 4 looked similar to this one Here are how the carptes tunred out Door panel cleaned and conditioned Next I cleaned all door jamb areas including the trunk. I used APC 20:1 and the swissvax brush to agaitate the solution o certain areas. This part got a little messy Before vacuuming and cleaning jampbs During After a wipedown with 1Z CP All water spots and dirt stains were cleaned off the under part of the trunk lid using another MF Trunk area before After Then back to the interior which needed a lot of work I used Gloss It leather cleaner 1Z CP on plastic Edge detailing sticks APC 5.5hp shop vac Door before Door after A 50/50 shot after cleaning with only the Satin leather cleaner from gloss it All small plastic trim was cleaned with 1Z CP Interior all finished off Trim was dressed using Adams In and Out spray - awesome product alternative to Black Wow if your in a hurry. Doesnt have the durability though Metal polished using Adams metal polish 1 Glass cleaned with 1Z Glas Polish and IG Finishing touches Tires dressed with Gloss It signature tire dressing, deep shine like Zainos but it lasts about 2x as long Key was cleaned with a toothpic and 1Z CP (it needed it) The LSP of choice was Gloss It Gloss Finish sealant x1 applied by the cyclo polisher using white finishing pads. Cure time is about 10mins, I just went around the car applying the Gloss Finish to each panel and by the time I finished it was about time to go and buff it off I followed up with a Gloss Enhancer QD wipedown The final results...I think this color really pops when clean but I would have liked to see what it would have looked like fully polished. Very nice clarity for a light colored car And one more... I was playing around in iphoto and came up with this as my new background for my computer, thought it looked artsy :computer: Hope you enjoyed and thanks for looking:thumb:
Nice work. Where do you get these GlossIt products? Also like that last pic. Wallpaper material there!!
It had crusty stuff all over it, I felt bad leaving a dirty key on a freshly detailed center console when the owner came to pick it up... ya know?
