dsms detail - 2010 Camaro SS Paint Correction
Discussion in 'Professional Detailer's Studio' started by dsms, Feb 3, 2010.
  1. dsms
    dsms DB Forum Supporter
    2010 Camaro SS
    Car in very clean shape with the exception of the paintwork that had some damage caused by the dealer. Some areas of the paint had only minor marring but other areas had clusters of scratches and swirls which needed a more extensive process for correction.
    The car came to me early in the morning, temperature was around 15 degrees so the usual wash process had to be inside to avoid frozen water on the finish.
    Before moving I was able to pressure wash the wheels and tires and clean them up as needed. Striping off dealership silicone based tire dressing was my main concern.
    Now inside I used ONR with a slightly different method of application. 1 sprayer bottled filled with ONR QD strength plus a little extra for added lubricity, 1 microfiber wash mitt and 1 bucket with a grit guard.
    I will only use this method on clean cars, caked up road grime etc. is not ideal for this wash method.
    Get your mitt saturated with water, wring out the excess and begin ONR washing panel by panel. Spray the ONR mixture onto the panel liberally to keep everything slick. This helps greatly for keeping water usage to a minimum, I do not have drains in my garage so keeping water off the floor is nice as well.
    ONR dispersing same as 2 bucket method
    Dried the car and began claying
    Dried once again after claying
    Before correction I gave the car a few alcohol wipedowns and then taped up the vinyl graphics and window trim.
    Measured the paint, some areas were a little low for a brand new car.
    Onto correction...
    Few random scratches on the hood
    Settled on a 2 step process for the correction, the deeper scratches needed a spot compounding pad to handle.
    Front fender before
    After
    Video 50/50 on the hood
    Drivers side needed a little more cut...
    Polishing stage
    Trunk area
    Before defects
    After correction
    Before
    And after
    Dealership sticker removed
    Swipe scratches on the trunk as well
    Sun shots after correction
    After 2 alcohol wipedowns, I pulled the car out in the sun to check for holograms etc.
    Back inside for LSP and finishing work
    Sealed the wheels
    Buffed off after 30mins
    Tires and wheel wells dresed
    Dressed the window trim
    Exhaust polished and rear valence dressed
    Engine given a wipedown and cleaned up the jambs
    Interior was in excellent shape, treated all the trim and dash with 303 for protection. Carpets cleaned up with Folex and doorjambs sealed.
    303 protection used on the vinyl graphics as well
    Finished shots
    Walkaround video
  2. Dust2Glory
    Dust2Glory Nuba Guru
    very very very clean
  3. trhland
    trhland Nuba Guru
    im loving that car!!! great job dave....
  4. slanguage
    very nice work Dave :thumb:
    who takes the shots of you working?
  5. leamangriffin
    leamangriffin Two Bucket System Washer
    nice work man. As usual.
  6. 911Fanatic
    Damn that looks cold David! Beautiful finish.
  7. billy
    billy Obsessive Detailer
    another great correction!!!
  8. supercharged
    Very nice work, Dave!
  9. dschia
    dschia Jedi Nuba
    Love your work dave, always enjoy reading your write up.
  10. Obsessive Detail
  11. Misha
    Misha Nuba Guru
    great work Dave. it seems that you use different sealant on wheels all the time. rejex and CG and others, why? different wheel = finish different sealant?
  12. Jedidiah
    Jedidiah Guest
    i like it when you work from home and not the client with 800 cars. makes me feel a little less green with envy.
    nice job!
    did it come with the wheel weights on the calipers to fix the shakeyness?
  13. fricker66
    fricker66 Birth of a Detailer
    Great work. Looks awesome.
  14. leamangriffin
    quicke question. What was the CG product you used to seal the wheels?
  15. bryansbestwax
    it depresses me to see so much damage on a new car, i know they don't leave that way
  16. michakaveli
    Nice Job Dave! Thanks for posting :thumb:
  17. detailersdomain
    looks great!
  18. Duratys
    Duratys Welcome to Detailing
    Nice work as usual :thumb:
  19. Carn
    Carn Welcome to Detailing
    Lovely looking car, great job as well Dave :thumb:
  20. ericosaur
    ericosaur Virgin Detailer
