dsms detail - 10' Camaro SS Full Correction
Discussion in 'Professional Detailer's Studio' started by dsms, Nov 21, 2010.
  1. dsms
    dsms DB Forum Supporter
    Chevy Camaro in for a complete correction and winter prep detail.
    -Car was bought with 8,000 miles on it
    -Dealer prep and polish job left paint with heavy defects and holograms
    Some before shots of the finish, lots of swirling, RIDS and machine holograms
    Example of how a hologram carries in the light
    The wash process
    -Foam w/ CG maxi suds
    -Soak with Optimum Power clean 5:1
    -Hand wash using Lusso Auto Bathe
    Car was then clayed and dried followed by several IPA wipedowns to remove any remaining protection, oils and clay residue
    Measuring the paint with a paint gauge, consistent readings all around
    Hood under the LED light, nice myriad of defects
    After a few test combos I landed on the following using both rotary and DA machnes. M105, M205 and Menzerna powerfinish.
    A 50.50 after compounding of some of the hood defects
    Pulled the car outside to check my work...
    Front fender 50.50
    Showing the difference in color between polished and unpolished paint... both are technically "black" paint :giggle:
    Closeup of some of the deeper defects
    The lower panels of this car took the most abuse, 50.50 of lower front fender vs. door
    Spot compounding
    Some of the body panels make for awkward polishing angles, improvisation as always is a staple in the correction process :thumb:
    I always open up doors during correction so I can polish all the way to an edge without my pad running onto an adjacent panel, especially one just polished out.
    Some areas required an extra hit during the compounding stage
    Some DA finishing on the trunk, new crimson LC pads are very nice!
    A 50.50 of the trunk, again lots of holograms
    Better pic of some of the deeper defects
    Under the LED
    The rear bumper had some of the worst holograms I have seen on a car and by worst I mean just careless buffing x10! Typical figure 8's pattern going up and down the entire bumper.
    Before, holograms and defects under standing halogen and LED lights
    After, same exact light source(s) in the same spot
    All in all the correction process took about 15hrs. After which a final IPA wipedown was given before LSP. LSP of choice was Menzerna powerlock.
    Wheels polished with Werkstat Prime followed by 2 coats of Rejex.
    Interior did not need much work. All leather was treated with the Leather Masters trio for a clean no shine look. 303 on the plastics and Jetseal on the doorjamps for protection.
    After shots of the interior
    Finished shots
    Thanks for looking :thumb:
  2. CG6Lemon
    CG6Lemon New Member
    awesome turnaround on the car. gj
  3. stottie
    stottie Birth of a Detailer
    wow that thing was a nightmare. poor car. loks awsome now great work. that interior is sick looking too
  4. Dust2Glory
    Dust2Glory Nuba Guru
    excellent and awesome write up.... I really like your latter write ups including steps and products used vs just showing pics with no info.
    Thank you
  5. PDJ3.2
    PDJ3.2 Birth of a Detailer
    Nice job returning that Camaro to proper form. It's bad enough the condition that particular one was in, but then you realize how many other "new" cars look just like that. I also like the idea of opening the doors to polish out edges easier. I think I'll give that a try
  6. rwisejr
    rwisejr DB Forum Supporter
    Great work as always Dave. That baby was seriously mistreated.
  7. Danny
    Danny Nuba Guru
    Man great work that SS was hammered.
  8. P1et
    Dave, that is a stunning bit of work you did!
  9. GDAL
    GDAL Guest
    Great work as usual Dave.
    How was the clear? hard or soft?
  10. Socal Brian
    Car with only 8,000 miles took a real beating to the paint and apparently the dealer didn't help matters. Now the customer will feel like he has a brand new car because now it looks better than new thanks to Dave.
  11. Pats300zx
    Stunning work Dave...
  12. 911Fanatic
    Beautiful job David!
  13. kakeuter
    kakeuter DB Forum Supporter
    Nice work Dave, always enjoy reading your write-ups.
    That before pic of the scratches by the Camaro badge really showed how bad that thing was.
    -Kody-
  14. detailersdomain
  15. domino
    domino Welcome to Detailing
    such a good looking car... i think the best of the latest retro-esque redo's, just needs a drop and some 22s
    good tip on the doors, never even occured to me - i always pop the hood and boot though
  16. Upper Class Detailing
    Great job Dave!
  17. tdekany
    tdekany Wax on..Wax off
    Excellent job Dave.
  18. billy
    billy Obsessive Detailer
    As usual great Job dave!!!
  19. bentley147
    bentley147 Jedi Nuba
    looking great !
  20. stingray23
    stingray23 Jedi Nuba
    looks great
