dsms - Black Porsche 911, my biggest correction!
Discussion in 'Professional Detailer's Studio' started by dsms, Nov 13, 2009.
  1. dsms
    dsms DB Forum Supporter
    Black Porsche 911, hands down the swirliest car I have corrected to date.
    I did this car well over a month ago, just haven’t had the time to sort through all the pictures and put a write-up together.
    Started off with the wash process. Did the wheels first, various wheel cleaners and brushes used. De-tarred the inner barrels Tires and wheel wells scrubbed.
    Ragtop pressure washed and cleaned first.
    Pre-soaked the finish with a biodegradable APC, needed the finish fully stripped before correction.
    2BM using concentrated shampoo/degreaser and MF mitts. I then clayed the car, used up 90% of a bar unfortunately.
    Clay after some of the hood...
    I dried the car with some DetailersDomain waffles and gave the paint an IPA wipedown to prep it for correction. All emblems and edging were taped off after the alcohol prep.
    Onto correction, paint had some issues ...
    The finish had a very hazed look, almost gray. Lost of rids, marring and some water etching.
    50/50 after the first 3 stages of correction, a total of 4 correction stages were needed to get the car to a 98-100% level. I waited to finish the car down completely until I did the final wash on it after all the compounding… lots of wetsanding combined with some wool correction makes for a very messy car with some splatter and residue.
    Much easier to just gently re-wash the car rather than continually doing alcohol wipedowns, less friction in trying to remove polish dots and residue when you use a slick soap and proper wash.
    In compounding with a very very aggressive method, 3-4 hits were needed to get out the very heavy defects.
    Video 50/50 of the hood
    Front bumper before
    Making progress...
    Rids on passenger front bumper, camera flash coupled with LED light
    After correction, same angle, lighting
    A-pillar before, under LED
    A-pillar after, under LED
    Working my way around the rest of the car, same stuff, different panels
    Before
    After
    Onto wetsanding, there were 6 clusters of scratches which needed wet sanding attention.
    4 of the 6 clusters were sanded starting with 1500grit paper, refined with 2000grit and then 3000grit to finish uniformly. The other 2 cluster were handled with 2000 and 3000.
    Gouges on the driver rear quarter
    After wetsanding
    Laid down a bead and corrected with wool at high rpm
    Scratches gone after a few passes with the wool, lots of hazing and micro marring to clean up
    Finished down
    Readings taken before during and after, still healthy readings after
    50/50 on convertible cover
    Working around the engine cover, taillights and bumperettes.
    More wetsanding on the passenger rear quarter. Smaller cluster in this area basically one big L type scratch
    After the wool correction L scratched handled, cleanup time next with follow up steps (2)
    After that another cluster was sanded
    Before
    sanded
    after (halogen handle in reflection unfortunately, no that’s not the old scratch)
    Door before
    Door after (left side only) after first 3 stages of correction, after which the car was re-washed and finished down
    50/50 passenger door
    Video 50/50
    [embed] [​IMG][/embed]
    After all the correction was finished (20 something hours worth) I re-washed the car. Foamed it first.
    Foam/degreaser + the wash did a very good job of cleaning the paint to prep it for final finishing.
    After drying the car I snapped 1 good sun shot, solid sunburst with almost no holograms made me very happy…. This made the final finishing process fail easy to carry out, the goal was to level the paint as much as possible BEFORE final finishing or jewelling and that stage to take it to the next level.
    Back inside to finish it down, I used some rotary and some DA for correction but for final finishing I prefer the rotary.
    3” pad worked well on the contours
    Finished final polishing around 5, gave it a final wipedown and pulled the car out to see the result before LSP
    After final polishing, no LSP
    Very happy with the level of clarity now, still some enhancements to be made.
    Pulled it back inside to apply LSP, do the interior and final touches.
    Interior was in okay shape, really wanted it to look brand brand new with a faint matte finish
    Seat cushions removed
    The leather was treated a few times to get rid of the slight greasy finish prior and leave a soft natural feel behind.
    Finished interior, I spent about 2 hours total on the inside.
    Keyhole, all plastic pieces etc finished up
    While the LSP was curing up all the trim and glass were done. Tailpipes before
    Tailpipe after. Wheels were then sealed, glass cleaned, all trim dressed etc.
    Excuse the leaves
    Seals treated
    Final shots, straight from the camera to Photbucket. Used Nikon D60 w/ kit lens.
    Finish under the LED, no defects, no holograms
    Long way from this…
    Took a long time to finally get this one up, now its done... and im curious what they'll say now :shrug:
    Time on the 911 was just under 30hrs, thank you for taking the time to read this whole thing
  2. jorge
    jorge Virgin Detailer
    Wow :yikes:
    Great job Mate, the after...and the before...:applause:
    Nice report!
    Best regards,
    Jorge
  3. slanguage
    what did you use to treat the seals?
    that car was beyond knakered. nice work :applause:
  4. 911Fanatic
    Stunning results David! Looks awesome. Those clarity shots before LSP are unbelievable. Looks like I'll have to step up my game a bit!
  5. Nikku
    Nikku Jedi Nuba
    Amazing work David. Thanks for taking us through this write-up. Enjoyed it thoroughly. As Ken said. Time to step up my game :)
    What did you end up using to compound in terms of polish?
  6. Prancing Horse
    Prancing Horse Any Rag Vehicle Washer
    Dude, that's incredible work. Thanks for another great write up. Those final reflection shots are just plain sick! :thumb:
  7. TONY MONTANA
    TONY MONTANA DB Forum Supporter
    that car was trashed very nice job
  8. detailersdomain
  9. invaderzim
    invaderzim Jedi Nuba
    nice, looks like I need to stop buying LSPs and work on polishing, at the first outside shot I thought it was done but then you took it up 2 more notches.
    I need a paint thickness gauge though as my cars scare me that their paint is too thin for a real correction.
  10. Chas
    Chas DB Forum Supporter
    David, that car was hammered! Awesome turnaround it looks amazing. Kudos.
  11. bentley147
    bentley147 Jedi Nuba
    woooooooooooooowwwwww ..good save
  12. Obsessive Detail
    Sweet job and nice writeup!
  13. matrix_808
    matrix_808 DB Supporter
    wow really great turn around. How long did all that take you?
  14. detaildoc
    detaildoc Guest
    Great job! What was your lsp?
  15. supercharged
    amazing work, David! I really enjoy those details of yours. Question, is there a reason you did some correction by PC instead of rotary? I'm still learing my rotary, but I can tell you for sure I'm not going back to PC, it's like polishing yourself instead of paintwork, I get so tired...
  16. Erik Mejia
    Erik Mejia Obsessive Detailer
    Nice save Dave. I see you had to take some L-Leucine to power through that detail. Good job.
  17. Denzil
    Man that Porsche was TRASHED! Great job at making the recovery!
  18. JLs Detailing
    Any reason for being so secretive about products??? Have to say this is the first detail on here that was so uninformative about products used. Just not usually the way I see it done here on DB.
  19. Auto Concierge
    Explanation inbound on why in a pm...................
  20. P1et
    From ashy to classy, wow! Some hard work went into this one apparantly!
