Drying towels
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by B.Prug87, Jan 1, 2009.
  1. B.Prug87
    B.Prug87 Guest
    I still use a synthetic chamois.i was curious what everyone else uses to dry cars with?
    Premium Quality Car Wash Towels Cotton Red
    does anyone use these??how well do they work?
    How are you supposed 2 use a waffle weave and cotton towels??For wat ever reason when i used my waffle weave it left streaks everywhere.
  2. PhoTuGo
    PhoTuGo Jedi Nuba
    I use waffle weaves they are amazing!
  3. billyblooshoes
  4. B.Prug87
    B.Prug87 Guest
    is there a certain way your supposed to use a waffle weave??because like i said mine left streaks.
  5. PhoTuGo
    PhoTuGo Jedi Nuba
    uhh i dont think so i just drag em accross the paint or u can blot
  6. D&D Auto Detailing
    Electric leaf blower, I almost never use my MF towels for drying.
  7. Denzil
    After sheeting the majority of the water, I use my wet/dry vac as it functions as a blower as well. After that, I just blot/wipe dry the remaining water with my WW towel.
  8. k33psp00lin
    k33psp00lin Any Rag Vehicle Washer
    I use WW to pick up major water and then follow with a plush MF towel
  9. slanguage
    I use the DD WW towels as well. I like them a lot.
  10. Buddy
    I like to use a leaf blower and a Cobra WW or just a WW...:thumb:
  11. smokin
    smokin Any Rag Vehicle Washer
    Danase PHAT TOWELS ARE AWESOME.
  12. jake_b
    jake_b Obsessive Detailer
    there's 1 brand that has not failed me yet. Carrand microfiber drying towel. I found it at Pep boys and it's for about $10. Very good towel IMO. I have used it a lot of times already and still performs good. no need for ringing..and for the price, it's all good. I tried also DD's waffle weave drying towel and it was good, I have used it once for now, first impression was good.
  13. Dannyk
    Dannyk Jedi Nuba
    Blower first, super type absorber next, waffle weave last. Seems the waffle weaves last forever.
  14. Asphalt Rocket
    Asphalt Rocket Nuba Guru
    Sheet the water and finish up with waffle weaves from Pakshak.
  15. blk45
    blk45 Jedi Nuba
    What do you mean "it leaves streaks"? As in streaks of water still on the paint? If so, then they either:
    A) aren't quality WWs and they aren't absorbing
    B) if they are quality and absorbed at one time, but aren't now, then you aren't washing them properly and they have absorbed something that is preventing them from doing their job
    or C) you are exceeding the capacity of them and you need to modify your drying technique and/or use more towels
    If the "streaks" aren't left over water, then obviously, something else has contaminated them and that residue is being transferred to the paint when you use them.
    FWIW, like a lot of the other suggestions, I sheet the water first, blow the vehicle off with a leaf blower and then dry what's left with a WW. Using this technique, the WW never even comes close to being fully saturated, so one towel will easily dry the whole vehicle. I have helped friends that didn't have a blower, and we would just sheet the water and then use the WWs. Usually, this scenario would require two towels to get the car completely dry. This is affected by the LSP on the car. If the LSP is working properly, the majority of the water leaves the surface when sheeting, so you can sometimes get away with one WW towel.
    What brand and size WW are you using?
    Did you wash them before you used them?
    What is your towel washing protocol?
    Do you use a QD with the WW when drying?
  16. k33psp00lin
    Sometimes using ONR I was getting left over streaking from my WW, I only noticed it on black cars but to get rid of the streak I follow up with another microfiber towel. I still haven't been inspired to get an electric leaf blower since I use ONR mostly.
  17. Reflect
    I think regardless what drying medium(besides a blower) it will leave a slight streaking remainder. This is just my experience, maybe I'm doing something wrong. Regardless, I like the Rag Shack's Amazing Dryer. With 2 of them I think you can tackle any job.
  18. 911Fanatic
    Poorboys WW Drying towels are my favorite so far, although I have 3 or 4 new ones awaiting testing.
  19. krshultz
    krshultz Nuba Guru
    I like these a lot as well.
    The "Vroom" drying towels at Target are surprisingly good. I've got two of them as well as two of the Rag Shack ones.
