Drying Before Claybar?
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by Handz, Nov 30, 2009.
  1. Handz
    Handz Obsessive Detailer
    I am very curious so i am going to ask.
    Right after you wash a car, do you prefer to dry the car before claybar or after claybar.
    I notice some people claybar the car while its still wet right after wash.
    discuss.
  2. richy
    If I have time to clay right after, I clay with some ONR sprayed onto the surface. If no time then I dry it with no drying aids and clay later when I have the time.
  3. Handz
    ^ So you omit the dry process post wash and go straight into claying after the wash?
  4. lifemal
    lifemal Wax on..Wax off
    A lot of us are on the clock and it's faster to just get the car out of the sun and claybar while still wet -- then dry each panel after claying. I just use a slightly stronger concentration of ONR when claying while still wet and haven't had any issues.
  5. 911Fanatic
    Claying while its wet doesn't harm anything. I always clay the car wet and wipe it down as I go.
  6. kc1337
    kc1337 Obsessive Detailer
    Doesn't claying the car when wet dilute the clay lube mixture?
  7. willjco
    willjco DB Forum Supporter
    I do not dry the car before claying because the water acts as lube on top of diluted ONR lube solution
  8. supercharged
    no, it's a waste of time...spray clay lube on wet paintwork and clay...then give it a good rinse or rewash if necessary...
