Doubt
Discussion in 'Interior Car Care' started by scoobymiguel, Dec 28, 2009.
  1. scoobymiguel
    scoobymiguel Virgin Detailer
    Hi,
    i just want a opinion, how can I remove oil from carpet car.
    regards.
  2. 911Fanatic
    If its motor oil, try some tar and adhesive remover like Autoglym if you have it. Its mild and shouldn't discolour the carpet. A strong citrus based cleaner should work as well. After, go over it with your choice of diluted APC.
  3. bryansbestwax
    a solvent based cleaner will do the trick, 3m adhesive remover works well
  4. raiderboy
    raiderboy Two Bucket System Washer
    Good advice
  5. bryansbestwax
    ya bad advice will give you a bad rap:thumb:
  6. scoobymiguel
    Thanks for the opinions, but i used the products from kleenrite,
    dissolve and the prespray.
    Works perfectly, í´m trying to put some pictures.
    regards
