So... When you guys clean up door jams, are you ever afraid to take all the grease out of the places where it should be, namely the hinges. Do you ever come back and put some grease/oil on the hinges? If so, what do you use? I usually come back with a little white lithium grease, and then wipe up the excess.
Duragloss#265 Ultimate Detail Spray, it works....Clean the grease off and spray some #265 on there......
