Dodge Nitro featuring Migliore Primo
Discussion in 'Show and Shine' started by Don, Jul 9, 2011.
  1. Don
    Don Banned
    This Nitro was in for a good cleaning. My girlfriend picked it up in the winter and while in decent shape to the average eye, it had a ton of light horizontal swirls which seem to have come from the tunnel wash. My goal was around 75% correction, with a simple one step polish.
    Products used:
    Migliore Citro Shampoo
    Migliore Naturale Shampoo
    Meguiar's new DA polish w/ microfiber pads (tested, wasn't impressed)
    Optimum Compound via Orange LC 6.5" pad
    Dodo Juice Clay Lube
    Rain-X
    Migliore Wheel Seal
    Migliore Bella Lustra Tire Glaze
    Migliore Primo
    Equipment:
    Foam Cannon
    PC
    EZ Detail Brush
    Lambswool wash mitt
    Overall - you can see the light swirls. The Nitro was just lacking life:
    I foamed with Citro, let dwell and rinsed. Then foamed with Naturale to wash:
    Clayed 50/50. Left clayed.
    I tested the new Meguiar's DA polish system with Microfiber pads. I wasn't happy with the results, although to be fair I was using the products in direct sun when they prefer shade. I switched out to the old trusted Optimum Polish / Compound pair.
    50/50 after the OC:
    100%:
    The Finals:
  2. Dust2Glory
    Dust2Glory Nuba Guru
    if you don't like the meg's stuff I'll take it off your hands!
  3. ziggo99
    ziggo99 Birth of a Detailer
    Do explain more on what you didn't like about them, how were you working it? I had excellent results when I used the kit.
  4. Don
    Don Banned
    Hi Gents,
    I primed the pad and spread with the PC on 2 and then worked in at 5. As noted, it was in the direct sun. Not saying I won't give it another try, just wasn't successful on this paint.
    If you have any suggestions to the proceed above, please share
  5. Kilo6_one
    why did you do it in direct sun? Honestly that would be my only suggestion....... maybe do it in the garage. Honestly Ive had less then stellar results with several products that say
    " ok to use in direct sun" I think in direct sun and heat are two different scenarios to be honest.
  6. Don
    Don Banned
    In this case, there wasn't proper lighting if I pulled into the garage. I'll have to try again in the shade, but I do prefer to work in the sun as in the end I find it the most honest critique of correction.
  7. Danny
    Danny Nuba Guru
    Nice job. Man there is no way in hell one can use any paintwork product in the sun here in El Paso, TX with temperatures above 100 degrees you would have to be insane. Any product would either flash so fast or dust if used during the day here the body panels get so hot you can probably cook and egg on them.
  8. Kilo6_one
    same here........ we used my BBQ infrared thermometer once on the hood of my car, 145 degrees. I doubt that is safe for any product out there. LOL
    and it was only 105 outside too.
  9. Kaban
    Kaban Welcome to Detailing
    Good work there my friend.
  10. dsms
    dsms DB Forum Supporter
    Actually if your using a powerful LED light in a garage to pick up on defects you can often times see more fine marks with that compared to out in sun. Ive picked up on minute things with the LED in my garage that I could not even see out in the sun.
