A little on this car its a RUF Rturbo 550 PS Here are the specs: RUF Rturbo 550 PS Power Output(DIN) - 405 kW (550 bhp) at Engine Speed - 6000 rpm Output(DIN) - 113 kW/L (153 bhp/L) Displacement - 3.600 cm³ Maximum Torque - 780 Nm at Engine Speed - 4000 rpm Compression Ratio - 9.4 : 1 Consist of: converted turbo charger, control unit, RUF intake manifold, sport air filter, RUF exhaust system and reinforced clutch It sounds and looks amazing the car is a full conversion! Condition: didn't look to bad until it was under the lights. Light scratches, some swirls. The results were great about 95% of the paint was corrected. This customer drives the car like it should be driven! Products used: Adam's Car Wash Shmitt Wash mitt and Shmitt Wheel mitt 2 Buckets with grit guard Jumbo Waffle Weave Drying Towel Microfiber Buffing Towels Boar's Hair Brush Spoke brush for the inner wheels Adam's VRT Adam's Glass Cleaner Adam's Detail Spray Adam's Clay Bar Adam's Metal 2 Menzerna IP Menzerna 85RD Phil's Secret Wax... (I have 2 actually, one that is about 25-29% Carnauba content in paste form (which you can apply with an applicator) and the other about 41-49% Carnauba content (this one is similar to the Zymol Vintage which you have to apply with the warmth of your hands. Its just to hard to handle with an applicator pad) P21S Wheel Cleaner Gel P21S Autowash Metabo (hi speed rotary) Firehose Nozzle Edge Pads Dual sides (6 inch) green/orange Edge Pads 2000 (4 inch) green (polish) orange (cut) 1Z Einszett Detail Spray Procedure: 1. Rinsed down the wheels (they were cool) 2. Sprayed down the wheels with some P21S Wheel Cleaner 3. Brush and cleaned the wheels with a Boar's Hair Brush 4. Rinsed down the wheels 5. Clayed the wheels (just the face/center, not a full wheel detail) 5. Rinsed down the car 6. Filled the buckets up with Adam's Car Wash 7. A great trick I use is to squeeze some Adam's car wash on the Shmitt giving it more suds as you clean. Going from top to bottom I typically go clean the roof then go to the bucket and rinse the Shmitt hitting the grit guard to make sure its clean for the next section (repeat this till the car is done) do this more frequently as you get to the bottom of the car and the back of the trunk/rear bumper. 8. Rinse car off throughly 9. Since there was no sun out and it was cool, I sprayed Adam's Detail Spray on the panels and proceeded to clay the car (Adam's Clay Bar) after each panel and each window was clayed I used the WW Drying Towel to wipe the excess detail spray off. 10. Car is clayed and dried. 11. Got out the Metabo with the green/orange pad and Menzerna IP 12. With a MF Towel I buffed off the Menzerna IP 13. Finished up polishing the car with Menzerna 85RD. 14. With a MF Towel I buffed off the Menzerna 85RD 16. Applied the Phil's secret wax to each panel and used a MF Towel with some 1Z Detail spray to wipe the excess off to a super wet/deep/shine.... 17. Cleaned up the windows with Adam's Glass Cleaner (interior/exterior) 18. Dressed the tires with Adam's VRT (did one pass on the applicator and did a pass using the dry side as the customer prefers a matte finish) 19. Used 1Z Detail Spray to do a final wipe down on the wheels. 20. Used the 1Z Detail Spray for a final wipe down on the car. 21. Wiped down the door jambs with 1Z Detail Spray 22. Adam's Metal Polish 2 on the tips Before: P21S Wheel Cleaner Gel in action: The wash: Shots after the wash and clay: Before driver's side door: After driver's side door: Before rear flare: After rear flare: Before right rear flare: [/B] After right rear flare: After shots (some major wetness and depth!) Final shot:
That is an awesome porsche!! alot of depth going there.... so, any samples of this special wax going to be handed out??!!
I was wondering when you'd post the pics. I know you mentioned it before. Well worth the wait. Great turnaround Phil!
WOW! That is awesome! I love that blue color! I'm not a fan of Porsches, not at all, but this one is just awesome! What is that secret wax of yours???
OMG look at his hat HOLDER on the wall?!?!?!? phil you have been to this client before did you sneak a better picture of it?
