Detailer's Domain: Porsche GT3
Discussion in 'Professional Detailer's Studio' started by detailersdomain, Sep 6, 2011.
  1. detailersdomain
    2007 Porsche GT3
    Not much needed in the paint correction department, however this car is driven as well as driven to the track for track days. Deep cleaning and light polish were needed to get this one back up and all nice.
    What was done -
    Exterior
    - Tires were spritzed down with Adam’s All Purpose Cleaner and washed down
    - Wheel wells were cleaned up
    - Bug and Tar Removal
    - Pre Washed with 1Z einszett W99
    - Wash down and rinsed
    - Door jambs were cleaned up
    - Clayed
    - Dried
    - Tires dressed
    - Masking
    - 1 Step Menzerna Super Finish
    - Inspection with Fenix,Infratech, and natural sunlight
    - Last Step - Aquartz
    - Wheel wells were cleaned and dressed
    - Rubber and Plastics Treated
    - Exhaust tips cleaned
    - Windows were clayed, cleaned, and sealed
    Interior -
    - Vac
    - Dash cleaned and protected
    - Leather cleaned and protected
    - Glass Cleaned
    Engine
    - Cleaned
    - Dressed
    Links to products used -
    1Z einszett W99
    Adam's All Purpose Cleaner
    1Z einszett Anti-Insekt
    1Z einszett Deep Cleaner
    Adam's Undercarriage Spray
    Uber Clay Bar Kit
    Aquartz
    Adam's Super VRT
    Adam's Metal Polish
    Adam's Glass Cleaner
    Engine
    Adam's In and Out Spray
    Interior
    Sonax Leather Foam
    Sonax Dashboard Cleaner
    Tools used
    Uber Wool Wash Mitt
    Uber No Name MF Towels
    Flex PE14-2-150
    Uber Buffing Pads
    Defelsko Paint Meter
    Brinkmann
    Kranzle Pressure Washer
    Cam Spray Foam Canon
    Uber Firehose Nozzle
    Metro Air Force Blaster
    Interior
    Before
    Sonax in tow
    After
    Exterior
    Before
    (will be using 1z einszett Anti-Insekt on this)
    Engine
    Before
    After
    Prep, wash, wheels, clay
    We were able to clean up the clear film on the rockers with 1Z einszett Deep Cleaner
    Before
    After
    After polishing shots
    After shots
  2. bryansbestwax
    Nice job phil, I love GT3's
  3. Socal Brian
    Very nice Phil!!
  4. hamza7
    hamza7 Welcome to Detailing
    Good stuff phil
  5. detailersdomain
  6. TimAD
    TimAD Jedi Nuba
    One of my favorite cars. Very nice job Phil!
  7. Michael @ einszett
    Michael @ einszett DB Certified Manufacturer
    Looks good! Phil, can you tell us how much W99 you use with the foam gun? We get this question often and I haven't personally used a foam gun. We typically recommend a dilution ratio of about 1:30 with most pre-cleaning but the foam gun is different.
    By the way, the W99 cap is graduated on the inside with a 15 ml marking (equals .5 fl oz).
    Thanks.
  8. JSF721
    JSF721 Jedi Nuba
    Phil, I have a thing for white Porsches and you did this one some serious justice.
  9. bakchoi
    bakchoi Birth of a Detailer
    Looks great! Do you use any product in between polishing with Menzerna Super Finish and Aquartz?
  10. kakeuter
    kakeuter DB Forum Supporter
    Looks great Phil!
    -Kody-
  11. detailersdomain
    thanks guys.
    we do use an ip wipe down.
  12. detailersdomain
    I will have to figure the exact but we have pretty much used 8 oz to the foam canon and we let the pressure washer do the mixing, its been working great to strip off the old last step, wheel wells etc.
  13. Chaseme
    Chaseme DB Forum Supporter
    What final percentage dilution do you prefer for IPA?
  14. detailersdomain
    50/50 is what I'm using.
  15. silber
    silber Virgin Detailer
    phil, is there a trick to getting the marks out of the rear rocker panel film? i own the same car in white and using the same product (1z deep plastic cleaner). there are still some spots which do not come out of the film -- look like yellow bug guts. what would you try next?
    thanks in advance and great job!
    will
  16. detailersdomain
    will I'm going to say the acid from the bug juice stained the clear film, its not always 100% effect. I tell most of my clients to replace them every so often to maintain a clean look.
  17. aowheels
    aowheels DB Pro Supporter
    Great work on a awesome car!
  18. detailersdomain
  19. silber
    seems strange it would be permanently stained after one day of sitting on there?? did you let it soak on the film before wiping? what about plexus or something else?
  20. detailersdomain
    plexus would work to protect it but yes a bug can stain after one day.
    just like bird crap etc.
