Detailer's Domain: Porsche 911 CS Cab - Ugh Water Spots
Discussion in 'Professional Detailer's Studio' started by detailersdomain, Dec 5, 2011.
  1. detailersdomain
    Received a call from the customer telling me that he would like his 911 CS Cab done. I'm thinking that's great! ........Then he tells me he has water spots on it, I ask how long have they been on there? If I recall right he said 6 months.
    What was done -
    Exterior
    - Tires were spritzed down with Adam’s All Purpose Cleaner and washed down
    - Wheel wells were cleaned up
    - Pre Washed with W99
    - Iron Cut
    - Wash down and rinsed
    - Door jambs were cleaned up
    - Clayed
    - Dried
    - Tires dressed
    - Masking
    - Paint Measurement
    - Meg's M105 with Surbuf Pad
    - Meguiar's DA300
    - Menzerna SF4000
    - Last Step – Aquartz
    - Wheel wells were cleaned and dressed
    - Rubber and Plastics Treated
    - Exhaust tips cleaned
    - Windows were clayed, cleaned, and sealed
    Engine -
    - Cleaned
    - Dressed
    Interior -
    - Vac
    - Wipe down and protect dash
    - Leather cleaned and conditioned
    - Glass cleaned
    Before - Interior
    After - Interior
    Before
    Water spots everywhere!
    Before - Wheels
    Sonax Full Effect Wheel Cleaner in action
    APC on the tires and wheel wells
    Wheels and tires cleaned up
    Raggtopp Cleaner on the top
    Before - Engine
    After - Engine
    Wash
    Rinse
    Iron Cut
    Rinsed
    Clay
    Claying Glass
    50/50 shots
    Fixed up the Clear Film not perfect but a big improvement
    Fenders
    Close up
    After - Not all removed but much much better
    Final touches
    Before - Tips
    After - Tips
    Pre Wow and Black Wow on the trim
    After shots
    Products used
    Links to products used -
    1Z einszett W99
    Adam's All Purpose Cleaner
    Uber Clay Bar Kit
    Meguiar's M105
    Meguiar's Microfiber DA Compound D300
    Menzerna Super Finish
    Aquartz Nano Coating
    1Z einszett Vinyl Rubber Care
    Optimum Metal Polish
    Glass
    Uber Glass Cleaner Kit
    Interior
    Leather Master Plus Kit
    1Z einszett Cockpit
    Engine:
    Engine Detail Kit
    Tools used
    Uber Wool Wash Mitt
    Uber No Name MF Towels
    Porter Cable 7424XP
    Uber Buffing Pads
    Defelsko Paint Meter
    Brinkmann
    Kranzle Pressure Washer
    Cam Spray Foam Canon
    Uber Firehose Nozzle
    Metro Air Force Blaster
  2. P1et
    Massive turnaround Phil, definitely one of the dirtiest Porsches we've seen in a while. And what's with the sudden increase of hard water on paint on DB?
  3. kakeuter
    kakeuter DB Forum Supporter
    Looks great Phil, hard water is such an issue here in Fort Worth.
    -Kody-
  4. dsms
    dsms DB Forum Supporter
    That was bad, great job!
  5. Pats300zx
    Looking good Phil !!!!
  6. cgthanos
    cgthanos Virgin Detailer
    Excellent job as always.
    Regarding the clear film treatment -- what exactly did you do? I have a c2s cab that I maintain with menzerna polishes, FMJ, and souveran and nothing seems to improve the light scratches on the clear film. I realize that it could be a completely different product that I have but I'm curious nonetheless how you made such an improvement in this film.
    thanks
  7. tdekany
    tdekany Wax on..Wax off
    What an excellent detail. Awesome work as always.
    On a side note, FYI, yesterday I worked on a 2002 745Li that had 10 years worth of waterspots on it.
    You have it easy :D Just saying.....
  8. v|nsan|ty
    v|nsan|ty Obsessive Detailer
    Are water spots harder to correct than swirls or RIDS? I have very limited experience with water spots as it doesn't affect me much. There was one instance where I had to wash on a sunny day and despite moving around quickly, I ended up with some water spots. I took care of them with PO85RD but I'm assuming it's much different for you guys.
  9. Socal Brian
    Fantastic job Phil!
  10. mikenap
    mikenap Jedi Nuba
    It really does seem like water-etched cars are showing up more and more. I know Bob has posted a few recently, and now this one. Anyway, awesome work Phil, it looks great now!
    Fresh waterspots are no problem. Light polish, clay or a QD will knock them out. Etched waterspots can be DEEP, too deep to safely remove sometimes. I've got a pic somewhere of where I sanded some scratches and waterspots on a hood. The RIDS came out pretty well, but you could easily see how much deeper the etched waterspots were, and there was no way I was going to chase those.
  11. detailersdomain
    I would agree with Mike.
    The problem with water spots are even though you get most of it off it will etch the paint, the 911 above had some serious etching so even though we brought out the guards red again under certain light you can see the outline of the water spots.
  12. rwisejr
    rwisejr DB Forum Supporter
    Great turn around Phil . I always enjoy your write ups.
  13. Auto Concierge
    Inset water spot etch especially on clearfilm is the bane of my existance.................................BY FAR the hardest thing to deal with when it is bad, btw Phil "Looks great".
  14. kyle butler
    kyle butler Birth of a Detailer
    So what causes the etched water spots? Is it hard water? rain?
  15. detailersdomain
    I want to say water spots are harder and have can damage the paint as oppose to swirls and rids which you can get rid of.
  16. detailersdomain
    hard water, acid rain etc.
  17. togwt
    The misnomer ‘water spots’ are likely to contain the atmospheric pollutants nitrogen oxide from motor exhaust emissions and sulphur oxide emissions from chemical plants, paper making and refineries, all of which can cause paint discoloration, surface etching and leaving microscopic surface imperfections and micro pores in the paint film surface that are vulnerable to deterioration, which should be removed and naturalized as soon as possible.
    These spots are recognizable by white or chalky rings that make the paint appear cloudy. Acid (acid rain, industrial fallout (IFO) hard water minerals (calcium and magnesium) alkali (from a sprinkler system) and of the above when mixed with moisture and heat (reactivity) will cause etching ((a concave circular mark and pitting)) each time moisture and heat are added the acid / alkali is reactivated and it permeates further into the paint surface, if left for too long they can become too deeply ingrained in the clear coat for ‘safe’ removal.
    If not removed, these minerals can permanently etch paint and glass. Quick detailers typically contain a wax or polymer and water, using them on an acid / alkali will lock the acid, allowing it to react with moisture and heat, which makes the acid more aggressive
  18. Meticulous-Detail
    Nice job as usual Phil! Might be comin up to c ya this week.
  19. Danny
    Danny Nuba Guru
    Very nice work Phil!
  20. AutoObsessed
    AutoObsessed Dealers
    Great turnaround Phil, looks like you guys have been really busy. Congrats :)
