Detailer's Domain: New Car Prep with Opti Coat - Lincoln MKX
Discussion in 'Professional Detailer's Studio' started by detailersdomain, Mar 12, 2013.
  1. detailersdomain
    Subject: Lincoln MKX
    Requirements: Clean up and prep for Opticoat
    Exterior
    - Tires were spritzed down with Adam’s All Purpose Cleaner and washed down
    - Wheel wells were cleaned up
    - Washed with Adam's Car Wash
    - Decon
    - Wash down and rinsed
    - Door jambs were cleaned up
    - Nano Scrub AutoScrub
    - Dried
    - Tires dressed
    - Masking
    - Paint Measurement
    - Menzerna FG400 - MF Cutting Pad
    - Sonax 3/6 Nano Polish - Uber Green Pad
    - Opti Coat
    - Wheel wells were cleaned and dressed
    - Rubber and Plastics Treated
    - Exhaust tips cleaned
    - Windows were autoscrubed, cleaned, and sealed
    Products used
    Links to products used -
    Auto Finesse Lather
    Auto Finesse Citrus
    Wolf's Decon Gel
    NanoSkin AutoScrub System
    Auto Finesse Rejuvenate
    Opti Coat
    Wolf's Glass Guard
    Auto Finesse Satin Tire Dressing
    Optimum Metal Polish
    Engine
    Optimum Power Clean
    Adam's In and Out
    Tools used
    Uber Wool Wash Mitt
    Uber No Name MF Towels
    Rupes Bigfoot LHR15ES
    Uber Buffing Pads
    Defelsko Paint Meter
    Fenix TK35
    Brinkmann
    Kranzle Pressure Washer
    Cam Spray Foam Canon
    Uber Firehose Nozzle
    Metro Air Force Blaster
    Before
    Presoaking the trim with AF Citrus
    AF Citrus was used on wheel wells and tires
    Wheel wells cleaned up
    Wheels were hit with Sonax Full Effect Wheel Cleaner and Wheel Woolies
    Wolf's Decon Gel
    Using the Uber Detail Brush to hit up the gas cap, jambs, etc
    Foam
    Wash with an Uber Wool Wash Mitt
    Rinse
    Customer requested debadging
    Before
    After
    Engine After
    Rupes Bigfoot and Auto Finesse Rejuvenate on an Uber Green Pad
    Auto Finesse Rejuvenate was used on the chrome trim as well.
    After
  2. Pureshine
    Pureshine DB Pro Supporter
    Great work Phil :).
  3. Holden
    Holden DB Forum Supporter
    Nice work Phil! A couple of questions......
    Did you apply opti-coat over af rejuvenate? :shead:
    Also, at what step did you use the wolf's decon gel? After pre-soak and rinse? After wash with wash mitt?
  4. detailersdomain
    we did the decon gel and the citrus during the prep cycle. decon on the paint, citrus on the wheel wells, tires, etc.
    we sprayed it down and then washed it.
    rejuvenate was used as a pre cleaner prior to the opti coat.
  5. .:RTime
    .:RTime Any Rag Vehicle Washer
    you dont rinse before you decon right? you rinse it off then foam and wash ect?
  6. detailersdomain
    on this one I did not rinse before decon.
  7. InsanePaint
    InsanePaint Pro Detailer
    Sexy Phil! Great work homie!
  8. detailersdomain
  9. sydtoosic
    sydtoosic Birth of a Detailer
    always a pleasure to see your work...
  10. Leonard Lee
    Leonard Lee Virgin Detailer
    Looks great!
