Detailer's Domain: Getting my car ready for the storm
Discussion in 'Professional Detailer's Studio' started by detailersdomain, Mar 3, 2013.
  1. detailersdomain
    Subject: My Daily Driver
    Requirement: Remove Salt and Grime and protect before Winter Storm Nemo!
    Exterior
    - Tires were spritzed down with Adam's APC
    - Wheel wells were cleaned up
    - Washed with a mix of Adam's Car Wash and Adam's APC
    - Wolf's Decon Gel
    - Wash down and rinsed
    - Door jambs were cleaned up
    - Nano Scrub AutoScrub
    - Dried
    - Tires dressed
    - Masking
    - Paint Measurement
    - Sonax 5/4 Fine Abrasive Polish - Uber Green Pad - Rupes LHR 21ES
    - Sonax Polymer NetShield
    - Wheel wells were cleaned and dressed
    - Rubber and Plastics Treated
    - Exhaust tips cleaned
    - Windows were autoscrubed, cleaned, and sealed
    Products used
    Links to products used -
    Exterior
    Adam's Car Wash
    Adam's APC
    NanoSkin AutoScrub System
    Sonax Fine Abrasive
    Adam's Super VRT
    Adam's Metal Polish 1
    Adam's Metal Polish 2
    Adam's Glass Cleaner
    Adam's Glass Sealant
    Tools used
    Uber Wool Wash Mitt
    Uber No Name MF Towels
    Rupes LHR 15ES Random Orbital Polisher
    Rupes LHR 21ES Random Orbital Polisher
    Griot's 6 inch Random Orbital Polisher
    Uber Buffing Pads
    Defelsko Paint Meter
    Fenix TK35
    Brinkmann
    Kranzle Pressure Washer
    Uber Foamer Attachment for Pressure Washer
    Uber Firehose Nozzle
    Metro Air Force Blaster
    RoboReel Power Extension Cord
    Before - not too bad but I just wanted to clean it up and get some of the salt off.
    Dirty wheels
    Did you know Sonax Full Effect works well with the Kwazar Venus Pro?
    Sonax Full Effect in action
    Wheel Woolies used to agitate the tough brake dust and salt
    Rinse
    Adam's APC plus Adam's Car Wash (4oz/4oz/balance water) use to cut out all the salt and dirt off the car (it can and will strip last steps)
    Shake well
    Nice thick foam
    After foaming we used an Uber Wool Wash Mitt to wash the car
    Rinse
    Beading shot of Sonax Polymer Net Shield - this was the test spot from 2 months back I did on the trunk deck - this was beading after the wash/apc mixture.
    [video=youtube;LqTw-IgT2ZE]https://www.youtube.com/watch?v=LqTw-IgT2ZE&list=UUC0yUZXAbtH1BIj2ZU1z9aQ&index=4[/video]
    Sorry no polishing shots, it was a light polish to remove the wash marks.
    After - not many afters getting dark
  2. Socal Brian
    Looks great Phil! How old is that application of net shield? Or did you apply after that wash?
  3. artemis53
    artemis53 Jedi Nuba
    If that Net Shield made it through the Adam's concoction he used, then it is worth MILLIONS! lol. In the "requirements" Phil says he also polished...so that mujst be a new application.
  4. Pureshine
    Pureshine DB Pro Supporter
    Wow! Love that car :)
  5. Socal Brian
    for sure your correct! I jumped to the photos and didn't look. my fault:doh:
  6. supercharged
    stunning work!
  7. Celtic Bob
    Celtic Bob Two Bucket System Washer
    Great job Phil. I have to do my new car soon. I am slowly picking up supplies before the snow melts. My car is black and covered in light swirls. Do I need a pressure washer to use a foam gun?
  8. detailersdomain
    actually guys that was after the apc and car wash mix! that was the test spot on the trunk I did 2 months back. its still holding up. I did not polish or redo the trunk, just the rest of the car.
  9. Auto Concierge
    Me likey the car and want to try the "Net shield".
  10. detailersdomain
    thanks Bob, believe it or not its already 4 yrs old!
  11. Upper Class Detailing
    Phil, can you use the Net Shield on glass and trim?
  12. detailersdomain
    I have not gotten good results I'll try it again and see. Its a bit cloudy.
  13. Upper Class Detailing
  14. detailersdomain
    of course
  15. Rcrew
    Rcrew Wax on..Wax off
    Phil- about how long would you estimate it took to apply the net shield to your S?
  16. detailersdomain
    from start to finish 8-10 minutes once you get the hang of it, the key is to apply it in a small section and wipe it off before it dries.
  17. Celtic Bob
    I hope I can get close to the same results on my new car.
  18. rjd598
    rjd598 Any Rag Vehicle Washer
    How many cars could the canister potentially do? Assuming correct application
  19. detailersdomain
    sure 7-15 depending on the size of the car.
  20. artemis53
    artemis53 Jedi Nuba
    WHAT?!?! That made it through a foam cannon with strong soap AND strong APC, and it looked like THAT?!
    That is insane!
    What is the cure time if layering?
