Detailer's Domain fixes a Range Rover due to improper wash technique
Discussion in 'Professional Detailer's Studio' started by detailersdomain, Dec 19, 2016.
  1. detailersdomain
    Detailer's Domain brings some life back to this Range Rover - Improper Washing
    Got a call from a great customer of ours asking us to help him out with his dad's Range Rover. He told us that the car is in bad shape due to improper washing. I said really why don't you fix it yourself. He said no time and it's too far gone. I said you have everything to do it. He said you don't understand he washes it with bleach and various home cleaning goods. :confused2 I said what! I told him if we do this you will have to teach him the right way to wash his RR, he said I can't promise you anything and this is a gift to him, what he does after he's on his own.
    Figured a quick run down on swirls removal and paint correction would help those on this article.
    What Is Car Paint Correction?
    AKA - swirl mark removal or machine polishing, paintwork correction is the reduction or removal of marks in the top layer of paint to produce a more refined finish.
    Paint correction can involves machine polishing of varying grades of cleanser, polish or compound. (can also be done by hand but in todays time and with todays finishing I would recommend machine polishing, preferably via an orbital polisher)
    Paint correction requires a high degree of skill and concentration, but done properly, it really can transform the look of a car by dealing with hard water marks, etching caused by bird droppings or bug and tar, swirl marks, scratches and fading or dull paint.
    Done professionally, paint correction is entirely safe and will not cause any issues for your paint.
    Why Consider Paint Correction?
    A vehicle’s paint has to deal with a lot of environmental challenges:
    Road grime and grit
    Bird muck, fly squash and tree sap
    Tar
    Water spots
    People brushing against the car with their clothing or bags
    Poor valeting techniques and/or products
    Poor machine or hand polishing techniques
    Auto car washes
    All of these things can leave the finish of a car looking less than perfect and at worst, dull, faded and covered in light scratches, swirls and other marring. Not only does this detract from your car's appearance but it ultimately reduces its value as well.
    For most, paint correction really can make a substantial difference and will completely remove or significantly reduce most marks. Not only this, but the resulting finish will have an amazing gloss, depth of reflection and slickness.
    Will swirls and paint issues reappear?
    New marks may appear over time (we can't stop future scratches), but with proper care you should be able to prolong them from reappearing.
    Paint Defects
    This project will:
    Remove all light haze swirl marks
    Remove any existing buffer trails/holograms
    Add an amazing shine and depth of reflection
    Restore most faded paint & reduce surface oxidation
    Create a stunning smooth/glossy finish
    Provide paint protection(3-6 months)
    Leave a slick feeling finish which is easier to clean
    This project will not:
    Remove the deepest swirl marks (circular scratches)
    Remove deep etching from bird muck, water, etc.
    Remove more than the very lightest of scratches
    Restore heavily faded paint or sub-clearcoat issues
    Improve the appearance of stone chipping
    Full list of products used during the new car process
    Exterior
    Nanolex Prewash Concentrate
    Nanolex Wheel Cleaner and Iron Remover
    Stoner's Tarminator
    Nanoskin Autoscrub Sponge
    Uber Clay Bar
    Nanolex Ultra Glass Sealant
    Nanolex Glass Cleaner
    Meguiar's M101
    Meguiar's M205
    Nanolex Tire and Trim Restorer
    Nanolex Spray Sealant
    Interior
    Nanolex Interior Cleaner
    Nanolex Textile and Leather Sealant
    Tools used:
    Metro Vac N Blo Car Vac Pro Series PRO-83BA CS
    Metro Air Force Blaster 8 hp
    Rupes LHR15 MKII
    Rupes LHR75E
    Meguiar's Microfiber Cutting Disc
    Uber Green Foam Pad
    Uber All Purpose MF Towels
    Uber Classic MF Towels
    Uber High Tech Glass Microfiber Towels
    Scangrip Multimatch Light
    Before shots
    Short on the prep shots but some foam shots and work flow shots
    Paint Correction
    Driver's Side Fender
    Before
    After
    Driver's Side Door
    Before
    After
    50/50 shots
    The biggest difference was on the piano black trim
    Much much improved this is not done yet, we had to finish it down further.
    Final shots
    rwisejr likes this.
  2. rwisejr
    rwisejr DB Forum Supporter
    Super job Phil !!! Looks a million times better.
  3. detailersdomain
    thanks I was very happy with the results.
  4. AndyThomason
    Amazing!!! I love your threads.
  5. GDAL
    GDAL Super Moderator
    Amazing work as usual Phil!
  6. detailersdomain
    thank you sir
