Subject: 2012 Ford Mustang GT Requirements - Paint Correction Exterior - Wheels were prepped with Sonax Wheel Cleaner and cleaned up with various brushes - Tires were spritzed down with Adam’s All Purpose Cleaner and washed down - Wheel wells were cleaned up - Washed with 1Z einszett W99 - Aquartz Iron Cut - Wash down and rinsed - Door jambs were cleaned up - Nano Scrub AutoScrub - Dried - Tires dressed - Masking - Paint Measurement - Meg's D300 with Microfiber DA Cut Pad - Griots Orbital - Menzerna SF4000 with Uber Green Pad - Griots Orbital - 1Z einszett Glanz Wax - Inspection with Fenix, 3m Sun Gun, Infratech, and natural sunlight - Wheel wells were cleaned and dressed - Rubber and Plastics Treated - Exterior windows and mirrors cleaned and sealed - Exhaust tips cleaned - Windows were autoscrubed, cleaned, and sealed Products used Links to products used - 1Z einszett W99 Aquartz Iron Cut Sonax Full Effect Wheel Cleaner NanoSkin AutoScrub System Meg's M105 Meg's D300 Microfiber Correction System Menzerna SF4000 Adam's Americana Wax 1Z einszett Vinyl Rubber Care Optimum Metal Polish Tools used Uber Wool Wash Mitt Uber No Name MF Towels Griot's 6 inch Random Orbital Polisher Uber Buffing Pads Defelsko Paint Meter Fenix TK35 Brinkmann Kranzle Pressure Washer Cam Spray Foam Canon 2 Grit Guard Buckets with Caddies Uber Firehose Nozzle Metro Air Force Blaster Before (not bad at all gloss was there) Prep - Wash, Iron Cut, NanoSkin AutoScrub, Wheels and Tires Sonax Full Effect Wheel Cleaner W99 for the wash Masking Before shots of paint 50/50 After correction Rinse After (sorry no outside shots on this one due to the rain)
only w99 was used, we only use it when we are ready to do the decon, autoscrub and a full correction.
Good job Phil and his team. Is the D300 and the mf cutting pad really that good? I see you use it on every detail write ups.
its a very good and really does a great job. there is a little learning curve but once you get it you can do a lot with it.
NIce stuff! Question Phil, are you using a led from your phone and flash with your dslr to take the pictures of the swirls?
