Detailer's Domain: 2010 VW GTI - Full Correction with Opti Coat
Discussion in 'Professional Detailer's Studio' started by detailersdomain, Jul 8, 2012.
  1. detailersdomain
    Subject - 2010 VW GTI
    Requirements - Full Exterior Paint Correction and Opti Coat installation.
    We get another one ready for Waterfest.
    Exterior
    - Tires were spritzed down with Adam’s All Purpose Cleaner and washed down
    - Wheel wells were cleaned up
    - Washed with 1Z einszett W99
    - Wolf's Decon Gel
    - Wash down and rinsed
    - Door jambs were cleaned up
    - Nano Scrub AutoScrub
    - Dried
    - Tires dressed
    - Masking
    - Paint Measurement
    - Meg's M105 with Surbuf and Griots Orbital
    - Sonax 5/5 Fine Abrasive Paste - Microfiber DA Cut Pad - Griots Orbital
    - Sonax 3/6 Nano Polish - Uber Green Pad - Griots Orbital
    - Opti Coat
    - Wheel wells were cleaned and dressed
    - Rubber and Plastics Treated
    - Exhaust tips cleaned
    - Windows were autoscrubed, cleaned, and sealed
    Products used
    Links to products used -
    1Z einszett W99
    Wolf's Decon Gel
    NanoSkin AutoScrub System
    Meg's M105
    Sonax Compound 5/5 - Coming Soon
    Sonax Nano Polish 3/6 - Coming Soon
    Opti Coat
    Adam's Super VRT
    Optimum Metal Polish
    Tools used
    Uber Wool Wash Mitt
    Uber No Name MF Towels
    Griot's 6 inch Random Orbital Polisher
    Uber Buffing Pads
    Defelsko Paint Meter
    Fenix TK35
    Brinkmann
    Kranzle Pressure Washer
    Cam Spray Foam Canon
    Uber Firehose Nozzle
    Metro Air Force Blaster
    Before
    Direct sun shots out side, Wow this is bad
    Prep - Wheels/Tires/Wash/Decon/Autoscrub
    Pre soak /Bug and Tar
    Wheel woolie in action (coming soon)
    Rinse wheels
    Rinse bumper
    Foaming up the car
    Decon
    Rinse
    Drying with the Uber Super Drying Microfiber Towel
    AutoScrub
    Blowing out the excess water
    Shots of the paint after prep
    50/50 shots (before and after compound and polishing)
    John in the background happy with the progress on making his baby shine
    Tail lights were cleaned up - Sonax 5/5 followed by Sonax 3/6
    Before
    After
    Close up shots after correction
    Action shots
    Outside shots after paint correction
    Rinse off all the dust from compound and polish
    Opti Coat
    Buffing off the Opti Coat
    After
  2. M3_GT
    M3_GT Virgin Detailer
    Great job as usual Phil.
  3. Rcrew
    Rcrew Wax on..Wax off
    Massive improvement!
  4. M3_GT
    How to apply the Opti Coat?
  5. detailersdomain
    thanks guys.
    DIRECTIONS
    1. Remove defects to your satisfaction
    2. Clean surface to remove all polishing oils, waxes, and silicone.
    3. Prime the applicator by making an X across the pad. Only a few drops will be needed for each subsequent panel.
    4. Wipe Opti-Coat on a single panel at a time in a thin layer using several directions for even coverage.
    5. Inspect the panel with adequate lighting withing 5-10 minutes looking for any thick areas that have not flashed away to clear.
    6. Use applicator or paint safe microfiber to even out (no pressure) any spots where you see streaks. This step is key, as any spots not leveled will have to be abrasively repaired is allowed to cure. Panels will feel a bit tacky and will beself -leveling during cure time, so avoid any unnecessary touching,wiping, or contact to produce the best results.
    7. Repeat steps 1-6 for each panelwhere application is desired.
  6. M3_GT
    Thank you Phil.
  7. Dust2Glory
    Dust2Glory Nuba Guru
    That is RED! Great job!!!!
  8. detailersdomain
    thanks guys!
  9. rwisejr
    rwisejr DB Forum Supporter
    That read really pops Phil. Awesome !!!!!!!!!!!
  10. P1et
    That looks so damn good.
  11. boredstudent3
    boredstudent3 Wax on..Wax off
    Nice work on the GTI. 3 step correction, eh? Must have been a lot of work
    How are the Sonax polishes working out for you?
  12. nymisano
    nymisano Virgin Detailer
    Curious why you haven't modified your foam gun bottle yet. 32 oz bottle + a bit of flexible tubing = far less refills.
  13. upsidedown
    upsidedown Virgin Detailer
    wow that is amazing... love looking @ your write-ups
  14. Jtrem
    Jtrem Virgin Detailer
    Looks great!
  15. goGTIgo
    goGTIgo Virgin Detailer
    Looks very nice.✌
    Sent from my iPad3 via Tapatalk
