Detailer's Domain: 2008 STI Mega Write Up!
Discussion in 'Professional Detailer's Studio' started by detailersdomain, Jul 20, 2009.
  1. detailersdomain
    Here is the long awaited DD Subie Write up.
    Where should I start, the mods I guess. Here is what I did before the complete detail was done. I researched and found all the parts I wanted to make this car look and handle a bit better.
    Take a look at the work done, I did just about all the install work myself less the AV system and a few bushings (needed a press to get some of the stock ones out)
    This car was a treat I never really did any of the wrenching myself so this was a great learning experience. One big lesson, the right tools and a lift are a HUGE Plus
    Take a look:
    Tuning mods:
    Harman DP (removed when the car was traded in) not installed yet -installed and loving it 3/17/09
    Harman Motive CAI
    Magnaflow CBE --> removed
    Invida Q300 CBE installed 3/2009
    Access Port (stg 2)
    Group N Engine Mount- installed 4/21/09
    STI Heat Sheid
    Exterior/interior:
    Rally Armour Mud Flaps.-->deleted
    Rear Bumper cargo strip (incoming) -
    Arm rest extension (incoming) -installed 3/17/09
    Rear Cargo Tray (incoming) - installed 3/17/09
    Piaa Xtreme White Plus High Beams (9005)- installed 3/09
    Piaa Plasma Ion Yellow Fogs -installed 3/28/09
    Perrin Super Shorty Antenna - installed 3/28/09
    Harman Motive Rear Overlay - installed 4/27/09
    Valentine One - hardwired 4/27/09
    Suspension:
    BC BR CO's installed 3/2009
    Whiteline Front Sways (22 mm) - installed 3/29/2009
    Whiteline Rear Sways (20 mm) - installed 3/29/2009
    Whiteline Sway Bar Support Brace - installed 3/29/09
    Whiteline Anti-Lift Kit - installed 3/29/2009
    Perrin Front End Links - installed 4/21/09
    Perrin Rear End Links - installed 4/21/09
    SPT STI Front Strut Bar - installed 4/27/09
    SPT Lower H Chasis Brace - - installed 5/1/09
    Whiteline 08+STi Positive Traction Kit- KDT902 - installed 5/1/09
    Whiteline 08+ WRX Rear Differential Mount Inserts - KDT903 - installed 5/1/09
    Whiteline rear camber adjusting kit 08+ wrx/sti hatchback subaru-kca326-- installed 5/1/09
    Whiteline Steering Rack Bushing kit 08+ - ksr207 -- installed 5/1/09
    Whiteline Rear Trailing Arm Bushing * W0568 -- installed 5/1/09
    Whiteline Front Control Arm Bushings - W0507 -on the way
    Stereo upgrades:
    Kenwood DNX 7140 installed by Mobilewerks 4/7/09
    JDM AV Panel installed 4/17/09
    The car in stock form
    At the dealer before delivery:
    The STI at its first mobile detail job nice and dirty after a couple snow storms
    Let the mods begin...
    First up the CO's, Exhaust, and Removal of the Mud flaps
    The BC Coilovers:
    instructions and adjusters:
    Install pictures:
    Frt stock:
    Set up and install:
    Loosening up and removing
    After shot:
    Adjusters on the front
    Rear install:
    before:
    after:
    Rear adjuster:
    Invidia Q300 Install pictures:
    the exhaust in the box:
    Getting ready to remove the Magnaflow exhaust
    Old exhaust removed:
    Joe doing the final install
    http://i46.photobucket.com/albums/f149/pyiu/08%20impreza%20sti/joeworkingontheexhaust.jpg[/IMG]
    Mud flaps on the car:
    Mud flaps off the car:
    Final shots of the car:
    my favorite shot:
    Next up the downpipes
    Extended arm rest install
    Extended
    Cargo Tray
    Rear bumper guard
    Tranny mounts
    Sways, Tranny Mounts, Bushings all getting installed
    More bushings
    Support Brace
    Strut Bar
    Endlinks
    Shorty antenna install
    Stock
    After
    Kenwood DNX-7140 Install (installed by the pro)
    AV Panel from Japan
    Stock panel with the new head unit
    After with the new Japanese AV Panel
    Random stuff
    Debadging the car
    Dental Floss
    Leftover adhesive and ghosting
    3M adhesive remover was used
    Compounding and polishing
    Final before and after
    Now onto the detail......
    Products Used:
    Exterior:
    Adam's All Purpose Cleaner in the Cam Spray Foam Canon
    Adam's Clay Bar and Optimum Instant Detail Spray and Gloss Enhancer for clay lube
    Menzerna Super Intensive with the Uber Orange Pad
    Menzerna PO85RD with the Uber Blue Pad
    Menzerna Top Inspection
    Lusso Prototype for Detailer’s Domain
    Einszett Spray Wax
    Wheels and Tires
    Uber Wheel/Tire/Wheel Well Kit see below for more of the wheel write up.
    Interior and Glass
    Adam's Glass Cleaner and Uber Glass MF Towels
    Leather Master Foam Cleaner (alcantara)
    Leather Master Nubuck Protection (alcantara)
    Leather Master Strong Cleaner (leather)
    Leather Master Vital (leather)
    Engine:
    P21S Total Autowash
    Adam's VRT Diluted with Water in a Spray bottle
    Trim:
    Black Wow
    Tools:
    Infratech 5300
    Brinkmann MaxFire
    Metabo PE12-175
    Makita 9227 Hi Speed Rotary
    The Uber Foam Pads (5.5inch)
    Tons of "Uber" Microfiber Towels
    Uber Drying Towels
    Cam Spray 1500A with Cam Spray Foam Gun
    Let's start with the wheels.
    Here is the set up, I have had the STI now for over 3000 miles and unfortunately I have had no time to give it even a proper wash, actually I haven't washed it yet. The day I figured I had some time it got just too hot to finish it. (98 degrees!)
    Anyway here is a teaser. I got started on the wheels and after 3000 miles of caked on brake dust I decided to go all out!
    By this I mean wheels were off the car, wheel wells were cleaned and dressed, brakes were polished and waxed.
    Products used:
    Uber Wheel Kit
    Menzerna PO85RD
    Sears Jack
    19mm Socket
    Ratchet
    Torque Wrench
    Cam Spray Pressure Washer
    Now to the pictures:
    Before shots of the wheels.
    Before Brakes and Wheel Wells. (reference left side, forgot to take all the complete shots, both sides were pretty dirty)
    Wheel being pulled off using ratchet and jack.
    Wheel off the car.
    Back
    P21S Gel on the wheels, I let it dwell while I cleaned the wheel wells and brakes
    Back of the wheel
    Front of the wheel
    What it looks like after P21S sits for a while, the P21S Wheel Gelis pretty thick.
    Cleaned both the front side and the back side with the Uber Boar's Hair Wheel Brush, The Uber Spoke Brush, and the Swissvax Wheel Brush, each one helped with the process of cleaning all that brake dust and dirt off the wheels.
    After I applied Swissvax Autobahn on them.
    Results from all that hard work on the wheels.
    Now that the wheels were done...on to the wheel wells.
    P21S Total Auto Wash was used to cut the dirt and grime off the wheel wells as well as the suspension bits, and brake calipers.
    Brushes were used to help clean up the wheel wells etc
    After everything was rinsed and cleaned up, I moved on to polishing the brake calipers with Menzerna PO85RD after I put a nice coat of Swissvax Autobahn on them to give them a nice shine and protection.
    Caliper After Polish and before Autobahn
    Applying the SV Autobahn
    Removing the SV Autobahn
    Adam's Undercarriage Spray was applied to bring back a nice new look to the wheel well covers (note I did wipe down any access to prevent a oily greasy look, I was going for a matte finish)
    Rear Before
    Rear After
    Front Before
    Front After
    After of the wheel back on the car (less the tire dressing)
    Of course the wheels were done again but much easier this time around.
    Take a look.
    Let's do the interior first
    Before
    After
    Prep
    Some before shots (this is how I got the car from the dealer)
    Before engine shots
    Cleaning up the engine
    P21S Total Autowash on all the areas with wax build up around the rubber trim, bug and tar etc.
    Now for the foam canon
    Claying the car
    Swirls everywhere
    Measuring paint
    After polishing under the Brinkmann
    After shots of the engine
    After shots of the car
    Last shot
  2. slanguage
    damn. still drive this thing or what? i thought you got an r32?
    nice work all around. came out looking brand new.
  3. detailersdomain
    sorry a bit of a delay...but the car was traded in for the r32.
    stay tuned for that write up.
  4. agpatel
    agpatel OD On Detailing
    Another great detail as always. Cant wait for the r32 write up.
  5. Smith2287
    Nice write up Phil, traded it in already haha? That sounds like something I would do. Looking at a 09 turbo and ditching the m3, I need more power!!!!!
  6. detailersdomain
    that would be a nice trade.
  7. trhland
    trhland Nuba Guru
    nice write up phil !!!
  8. Smith2287
    I saw on another forum don't you have a 996 turbo?
  9. billyblooshoes
    great write up phil. i particularly enjoyed the first half which overviewed your mod process. very nice and tasteful mods, my kinda guy. looking forward to the writeup on the R32.
  10. detaildoc
    detaildoc Guest
    Nice! I should bring you my car, so you can pimp it also.
  11. detailersdomain
    thanks guys.
    smith yes I have one of those as well :)
  12. Asphalt Rocket
    Asphalt Rocket Nuba Guru
    Great job Phil, a very indepth write up for sure.
  13. DaveS4
    DaveS4 Jedi Nuba
    Looks great Phil! You scared me for a second with that first picture of the drivers side camber plate...glad to see that it was oriented correctly in the later pics. ;)
  14. detailersdomain
    yup you learn a few things when you do the installs yourself.
  15. dsms
    dsms DB Forum Supporter
    More credit to you! Great work Phil. I really liked the STi setup.
    .... now you have to start all over again with the V-dub:doh:
  16. richy
    Good Lord Man..that's a lot of work!! I need to go have a smoke......
  17. k1msta
    k1msta Guest
    oh man thx for the write-up phil.. i was looking into getting one for myself after my lease is up, either that or spend little more money and get a g37s.. and great job :applause2:
  18. Nica
    Great write up and looks like doing those mods your self was lots of fun. Vehicle looks great :thumb:
    So you traded this vehicle? After you did all those mods? Why?
    Just wondering that's all.
  19. 911Fanatic
    Car looked great Phil! Even happier you are onto a Vdub! Please post pics!
  20. SpecC
    SpecC Wax on..Wax off
    it's a shame the STI had to go :(
