Detailer's Domain: 08 Mercedes E350
Discussion in 'Professional Detailer's Studio' started by detailersdomain, Nov 16, 2011.
  1. detailersdomain
    What was done -
    Exterior
    - Tires were spritzed down with Adam’s All Purpose Cleaner and washed down
    - Wheel wells were cleaned up
    - Pre Washed with W99
    - Iron Cut
    - Wash down and rinsed
    - Door jambs were cleaned up
    - Clayed
    - Dried
    - Tires dressed
    - Masking
    - Paint Measurement
    - Meguiar's DA300
    - Menzerna SF4000
    - Last Step – Wolf's Nano Sealant
    - Wheel wells were cleaned and dressed
    - Rubber and Plastics Treated
    - Exhaust tips cleaned
    - Windows were clayed, cleaned, and sealed
    Links to products used -
    1Z einszett W99
    Adam's All Purpose Cleaner
    Uber Clay Bar Kit
    Meguiar's Microfiber DA Compound D300
    Menzerna Super Finish
    Wolf's Chemicals Nano Sealant
    1Z einszett Vinyl Rubber Care
    Optimum Metal Polish
    Uber Glass Cleaner Kit
    Tools used
    Uber Wool Wash Mitt
    Uber No Name MF Towels
    Porter Cable 7424XP
    Uber Buffing Pads
    Defelsko Paint Meter
    Brinkmann
    Kranzle Pressure Washer
    Cam Spray Foam Canon
    Uber Firehose Nozzle
    Metro Air Force Blaster
    Unfortunately we had no sun shots due to the weather.
    Before
    Tire dressing splatter
    APC on the tires (you will see we needed more later on)
    Wash
    Iron Cut
    Clay
    Drying with the Uber Super Drying Towel
    Before
    After
    Hard to see but left side compound and polished and right side not touched
    This is what happens when you use cheap tire dressing and/or don't apply it correctly.
    The tire dressing that caused all that kick up
    Cleaned all the cheap stuff off
    After tires
    Exhuast tips before
    After
    After
  2. P1et
    Nice work Phil, lots of white cars recently!
  3. mrgolfrider
    Looks like there is just enough space to work around that car.
  4. rwisejr
    rwisejr DB Forum Supporter
    Sweet job Phil that white looks candy coated !!!
  5. kakeuter
    kakeuter DB Forum Supporter
    Nice work Phil, good job stripping the tires properly as well.
    -Kody-
  6. detailersdomain
    thanks guys! I really wish I got before and after sun shots but the last few days have been cloudy and wet.
    it was bad. (C280 from a couple months back bad)
    more white cars to come....its either white or black.
  7. sal329
    sal329 Nuba Guru
    looks great nicely done
  8. nlpamg
    nlpamg Virgin Detailer
    very nice! what tire dressing did you use?
    I use Adam's VRT and use it sparingly, but it still manages to sling!
  9. detailersdomain
    do you prep the tires and remove all the dirt/grime/and old dressing off the tires first?
  10. detailersdomain
    tire dressing used on this car was 1Z einszett Vinyl Rubber Care
  11. Socal Brian
    Very nice Phil!
  12. DaytonaJae
    DaytonaJae Birth of a Detailer
    Phil this mercedes is my daily driver, down to the color and wheels - it scared me at first - I had to check in the garage to make sure it wasn't stolen... Needless to say I especially enjoyed this write up - seems almost like I was reading about my own car being detailed by you.
  13. detailersdomain
    thanks Jae, email sent back.
  14. nymisano
    nymisano Virgin Detailer
    what did you hit the tires with to strip the second time around?
  15. detailersdomain
  16. nlpamg
    What do you mean by prep? I let the wheels/tires soak in the foam gun solution and then I use a brush and some carwash on the tires. Nothing else. How do I properly prep the tires?
    Thanks!
  17. Frankastic
    Prep is preparation : clean tires thoroughly for its to accept any tire dressing. Most of the time, car wash isn't going to cut it.
    you will need some all purpose cleaner, towels, and a good tire dressing to start. + stoner tarimator for some really greasy Tire dressings
    something like this kit will do
    click it
  18. supercharged
    amazing work, Phil! Love this benz!
  19. teak
    teak Birth of a Detailer
    First rate as always. I really should purchase some Wolf's Nano sealant, as the appearance is glossy and wet.
  20. detailersdomain
    thanks guys!
