This daily driven, Seal Grey 996 911 Turbo, with 60k miles was corrected by us at Good Vibes Autosport. While a daily driven, considerably milled car, it was in rather decent shape. Definitely many swirls and defects on the vehicle, however definitely kept in great shape being a garaged vehicle. The car was conditioned all around, as the pics will speak for themselves! Products used Meguiar’s M105 and yellow pad (some place wool was needed) Menzerna 203 and green pad Menzerna 106 and white pad Jetseal109 and blue pad Wolfgang Fuzion wax Meguairs Superdegreaser P21S TAW P21S Polishing soap P21S Finish restorer CG wheel cleaner Rejex Before pictures of paint Paint correction needed Meguiar’s M105 on yellow pad because of deep scratches, spoiler and rear bumper needed purple wool pad. After this car was followed with Menzerna 203 in some areas and in some with Menzerna 106. Paint was cleansed from polishing oils with P21S paint cleanser, then sealed with Jetseal109 and left to cure for 20 minutes, then removed and allowed to cure for another 20 min per instructions, Fuzion wax was applied and removed. 50/50 paint correction pictures after Meguair’s M105 and yellow foam pad Wheels were cleaned with CG wheel cleaner, tires cleaned with Meguiar’s Superdegreaser. Tires were dressed and wheel sealed with Rejex Wheels before/after Headlights were wetsanded with 1500 and 2000 grit sand paper, polished with Meguiar’s 105, Menzerna 203 and 106 and sealed with Blackfire Wet Diamond Tail lights polished with Meguiar’s 105, then with Menzerna 203 and followed up with Menzerna 106 Exhaust tips were cleaned with P21S polishing soap and polished with P21S finish restorer, sealed with Rejex Before/After Reflection/final pictures Thanks for reading! Oakes
M, GREAT job! You worked magic. Now all that car needs is to loose the turbo twisties and put on some 997 turbo wheels. Outstanding job! Thanks Mikael! Joe D
