decontamination pair
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by grease, Apr 26, 2010.
  1. grease
    grease Birth of a Detailer
    Would the decom pair work as a wheel cleaner for really baked on brake dust?
    I cant find any Megs WB in Canada, or any other wheel acid, and my wheels are desperate... The Ricardo clays combined with Megs Hot Rims and Orange Lightning Wheel Cleaner (ABFL acid 0.5%) wouldnt touch it.
  2. getcha
    getcha Jedi Nuba
    Yes the acidic portions of decon kits would work. Keep in mind these are designed to dwell for a few minutes as opposed to stronger wheel acids which are made to dwell for shorter time and rinsing fast. But yes they will work provided the wheels are not bare metal exposed..
  3. togwt
    Try SONAX Wheel Cleaner full effect, a safe 'acid' that will clean any wheel without the risks associated with acids
  4. getcha
    getcha Jedi Nuba
    Sonax won't touch the kind of crap I think the OP is dealing with...
  5. Pmach
    Pmach Virgin Detailer
    Do you have access to a steamer? I've heard steam cleaning can do wonders for such baked on brake dust. You could always rent if worse comes to worse.
