DD and the Carrera GT
Discussion in 'Professional Detailer's Studio' started by detailersdomain, Oct 17, 2007.
  1. detailersdomain
    Alright I have to say when I got the call from my customer on this one I was very excited [:D]
    The Porsche Carrera GT! Red on Black! 5000 miles in pretty good shape, it needed a very thorough claying, and had some swirls and light scratches that needed to be polished out, and off course the Swissvax Treatment! The interior was cleaned up and the engine was wiped down.
    Time: about 8 hours (2 in the crew)
    Take a look:
    Products Used:
    Adam's Car Wash
    Adam's Clay Bar with Adam's Detail Spray as lube
    Adam's VRT
    Adam's Glass Cleaner
    Adam's Undercarriage
    P21S Wheel Cleaner Gel
    P21S Autowash
    Menzerna 106
    Menzerna Top Inspection
    Swissvax Cleaner Fluid
    Swissvax Concorso
    Einszett Leathercare
    Einszett Cockpit
    Einszett Glas Polish
    Tools:
    3m Sun Gun
    Metabo 12-175 with Green and Blue E2K pads
    Karcher pressure washer
    Tons of towels
    Procedure:
    Exterior:
    1. Rinsed down the wheels
    2. Sprayed down the wheels with some P21S Wheel Cleaner
    3. Sprayed down the wheel wells and tires with P21S Autowash
    3. Brush and cleaned the wheels and tires with a Boar's Hair Brush and Spoke Brush
    4. Rinsed down the wheels, tires, and wheel wells
    5. Rinse the car down
    6. Used Adam's Car wash (the water pressure was pretty bad so we opted on not using the foam gun)
    7. Rinse car off throughly with a Karcher pressure washer
    8. Brought the car in and proceeded to clay the car using Swissvax Paint Rubber(yellow/ super fine) and Detail Spray removed the excess detail spray
    9. Masked the car and taped off the clear bra sections.
    10. Used the Metabo with Menzerna 106 to polish out all the imperfections. (blue pad) a few passes per panel at 1500 rpm (Metabo rotary)
    11. After each section was corrected I buffed off the excess polish with a MF Buffing Towel.
    12. Spritzed some Menzerna Top Inspection before another look with the 3m Sun Gun.
    13. Applied the Swissvax Cleaner Fluid and removed with MF Buffing Towel
    14. Applied the Swissvax Concorso by hand and remove with MF Buffing Towel
    15. Cleaned up the windows with Adam's Glass Cleaner (interior/exterior)
    16. Polished up the glass with Einszett Glas Polish applied by hand removed by hand
    17. Dressed the tires with Adam's VRT
    18. Dressed wheel wells with Adam's Undercarriage Spray
    19. Used Adam's Detail Spray to clean off the wheels.
    20. Used the Adam's Detail Spray for a final wipe down and inspected the car.
    Interior:
    1. Vacuumed the Interior
    2. Wiped down the door jambs with Adam's Detail Spray
    3. Cleaned Windows with Adam's Glass cleaner and then polished with Einszett Glas Polish
    4. Interior cleaned with Einszett Cockpit on the dash and everything else that was not leather
    5. Cleaned and Conditioned the leather with Einszett Leather care
    Engine:
    1. Wiped down the dust with a MF towel misted with Adam's Quick Detail Spray
    2. Rubber and plastics treated with Adam's In and Out Spray
    Interior Before:
    Me brushing away:
    Interior After:
    Engine:
    Before shots:
    Dirty wheels (ceramic brakes create very little brake dust)
    P21S wheel cleaner gel in action:
  2. detailersdomain
    Vacuuming out the vents (lots of loose road debris in there)
    Washing:
    First shot little to no pressue
    Washing the car down:
    Final rinse:
    Swissvax Paint rubber (claying):
    Dan from Concierge Motors attention to detail
    Masking away:
    Imperfections it hard to tell but its there:
    After Polish:
    After Swissvax Cleaner Fluid:
    Concorso:
    Concorso applied:
    Dan removing the Concorso:
  3. detailersdomain
    Tons of Afters:
    Last shot:
  4. D&D Auto Detailing
    Welcome Phil. Sweet detail!
  5. detailersdomain
  6. D&D Auto Detailing
    Why should the cleaner fluid be used? Whats the difference between that and an alcohol wipe down? And how do you like that paint rubber?
  7. pirex
    pirex DB Certified Dealer
    Welcome! Very nice work, love the attention to details ;) Thank your for all the pictures :)
  8. Nica
    That's what I'm talking about such a sweet, sweet, sweet vehicle..man I'm going to print one of those pictures and post it up on my office wall (I'm still at work :()
    Man that is such a nice vehicle and you guys did an incredable job at detailing that. If I ever get an opportunity to detail such a vehicle I don't know how fast I'd be able to do detail it...I would be way to busy picking up my jaw from the floor...or wiping the droole of the vehicle lol...
    Thanks for sharing
  9. Asphalt Rocket
    Asphalt Rocket Nuba Guru
    great detail phil, glad to see you over here.--Dana
  10. Calgarydetail
    first, welcome to db.
    and wow, very nice work. I have never seen one of those in red, it defintly suites it.
    very nice wor
  11. klumzypinoy
    klumzypinoy Nuba Guru
    I don't know what's better, this or the Lambo! You guys do awesome work :D
  12. 02CAMSS
    02CAMSS Jedi Nuba
    Swissvax is next on my list.High end products rule.
